QUICK! Transfer case removal - JeepForum.com
post #1 of 31 Old 07-15-2010, 03:40 PM Thread Starter
cubewhiz
Driveshafts removed, skid plate removed, transmission & t-case supported with jack stands.
How does the t-case come down? I see 5? bolts that connect the t-case to the transmission and the shifter is bolted to the transmission. Is that all? Remove the bolts and slide it out and down?
Thanks.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #2 of 31 Old 07-15-2010, 03:43 PM
bigbelman2009
yeah pretty much
bigbelman2009 is offline
post #3 of 31 Old 07-15-2010, 03:45 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
There are 6 bolts.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 31 Old 07-15-2010, 03:45 PM
Louie4
Yep. Don't forget to disconnect the linkage to the shifter.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 31 Old 07-15-2010, 03:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
And the vent hose!
Max
Mean Max is offline
post #6 of 31 Old 07-15-2010, 03:52 PM
Ptr
1992 J-Series Truck
and the speedometer connector
Ptr is offline
post #7 of 31 Old 07-15-2010, 03:57 PM
trw
2011 JK Wrangler
and the 4WD vacuum harness
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #8 of 31 Old 07-15-2010, 03:58 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
And drain the fluid first, otherwise you get an ATF bath.............
don't ask.............
Max
Mean Max is offline
post #9 of 31 Old 07-15-2010, 05:46 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
You guys are too funny...
Here ya go, man. I did a blow by blow on pulling the TC to get to my transmission seal so you can follow along at home.......
http://www.jeepforum.com/forum/f12/a...-pics-1041722/
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #10 of 31 Old 07-15-2010, 06:36 PM
timatoe
timatoe's Avatar
I'd suggest having the Jeep high enough that you can just sorta lower the T/C down onto your chest and roll out on the creeper. It's not all that heavy but it's really awkward to try and lift or lower to the side, if that makes sense. Same thing getting it back in, I sit on the creeper, sit the T/C on my legs, grab it and lay back, rest it on my chest and then roll under. Pretty easy at that point to just press it up and stab it in place.
timatoe is offline
post #11 of 31 Old 07-15-2010, 07:01 PM Thread Starter
cubewhiz
Indeed, I got it out. Thanks!
Drained the fluid before I did anything else!
Max, I only had five bolts, but there was a hole for the 6th. It is apparently missing! Anybody other than dealer for it? It looks like some sort of stud with a nut on it. Also, are they all the same size? I noticed the nut was a little deeper on some, but does it matter if I put them back in the locations they came from? Thanks.
I noticed the vacuum hose while I was disconnecting the linkage and then pulled the speedo cable out. I had to cut the clamp off the vacuum hose. I suppose small hose clamp will replace it.
It was kind of light, but I had a helper to help me lower the case. It's sitting in my garage and the front yoke nut is already off.
Thanks a ton!
cubewhiz is offline
post #12 of 31 Old 07-15-2010, 07:22 PM
RikRotorhead
You have the BA10/5 tranny and NP231/AMC t-case. There are only five nuts holding it to the tranny. You only need to remove the mode selector linkage nut in addition to the vacuum switch hoses and vent hose.
The NP231/J has six nuts holding it to the AX15.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #13 of 31 Old 07-15-2010, 07:24 PM
RikRotorhead
Also be certain the gasket between the tranny and t-case doesn't get damaged. There is no orientation on it.
RJC#512
post #14 of 31 Old 07-15-2010, 07:42 PM
Feetwet
Enjoying the Ride
Feetwet's Avatar
His profile has the AX5 behind a 2.5L. with Np231 J, which has a 6 bolt setup. The studs screw into the TC about halfway, then the 9/16"nut tightens it all together. Are we all talking about the same drivetrain?
Feetwet is offline
post #15 of 31 Old 07-15-2010, 07:43 PM Thread Starter
cubewhiz
You mean the AX5? I have a 1995.
cubewhiz is offline
Transfer Case Plug Removal davecam TJ Wrangler Technical Forum 8 11-29-2008 02:24 PM
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 02:01 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 05:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 10:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 07:21 PM
