quick question???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > quick question????
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wdHey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 10-26-2011, 10:33 PM   #1
AUREDFISH
quick question????
well i need a lift for dd use was just conserding a add a leaf and shakle lift along with 1 inch body jus
AUREDFISH is offline   Reply With Quote Quick reply to this message
Unread 10-26-2011, 10:39 PM   #2
94chb
hi welcome to the forum please fil your profile out so we know what you have.
then you need to give us more info
like
what size tires are you planning on running?
94chb is offline   Reply With Quote Quick reply to this message
Unread 10-26-2011, 10:47 PM   #3
moonshinefuel
I like it. Id just limit the shackle lift to no further than one inch beyond factory length.
The add a leaf.. you would probably be best to find oem stock Yj leafs, take the longest leaf out of each spring, cut the loops/wraps off, and those to the packs. That should alone get you close to an inch boost.
AX5/NV3550 Conversion Thread. http://www.jeepforum.com/forum/f12/n...irrels-752742/
Bow Hunting www.bowsite.com
moonshinefuel is offline   Reply With Quote Quick reply to this message
Unread 10-26-2011, 11:09 PM   #4
AUREDFISH
would like maybe 32 11.00 on 8 inch rim
Unread 10-26-2011, 11:10 PM   #5
AUREDFISH
does it have to be a stock jeep leaf spring say if i wanted to take a leaf out of heavy duty ford springs was contemplating that as well
Unread 10-26-2011, 11:22 PM   #6
94chb
have you looked into a 2.5 - 4 in suspension lift? then put a 1in body lift. then you will be good to go.
Unread 10-27-2011, 11:43 AM   #7
AUREDFISH
looking for the cheapest route did the math and add a leaf is cheaper route to take
Unread 10-27-2011, 11:53 AM   #8
Que89YJ
Cheapest = shackles, body, and TJ flarers.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 10-27-2011, 12:14 PM   #9
94chb
you have a yj its spring under, add a leaf isnt going to add a lift like if you had a cherokee.
2in body lift
1in shackle lift
that will be your cheapiest route.
