quick Q.. NP231 fluid capacity? - JeepForum.com
post #1 of 5 Old 05-04-2005, 09:07 PM Thread Starter
kaffeene
How much fluid does the NP231 T-case hold and should I use ATF 4 or 3??
thanks
12' JKU Rubicon
kaffeene is offline
post #2 of 5 Old 05-04-2005, 09:23 PM
boomhower
takes 2 quarts ATF. not sure what you mean by 3 or 4. in the haynes manual the t-case calls for 2 quarts of dextron/mercon III ATF, which is equivalent to dextron/mercon II, if thats what you mean? ???
--1991 JEEP YJ 2.5l-- (trail beater)
RE 4". AA SYE. TW driveshaft. 33" TSL's. Snorkel. Olympic Rear Bumper. Warn XD9000i. Optima Yellow Top. Herculined Interior, Grill, and Rockers. TJ Flares. Cobra 19DX CB. Firestik antenna.
boomhower is offline
post #3 of 5 Old 05-04-2005, 09:27 PM Thread Starter
kaffeene
Just whether its ATF 3 or ATF 4. I heard that either can be used but just wondering.
12' JKU Rubicon
kaffeene is offline
post #4 of 5 Old 05-05-2005, 08:45 AM
JeepCrz
Mine says 2.2 pints of ATF dextron 3. When I filled it I used 1 1/2 quarts till it ran out the fill hole. :shrug:
2010 Jeep Liberty > Stock < wife's
1989 Jeep Wrangler > 4.0 conversion, 4" lift, 33's
1985 Jeep CJ7 > AMC 360, 4" Lift, 35's, locked front and rear, winch, Onboard Air, ect..
JeepCrz is offline
post #5 of 5 Old 02-14-2013, 06:44 AM
barillms
Filled min today, it took about 1.75 quarts.
ATF -3
barillms is offline
NP231 Capacity? grangalan YJ Wrangler Technical Forum 4 12-21-2008 06:42 PM
35, 30 fluid capacity Isaiah17 YJ Wrangler Technical Forum 3 11-18-2008 03:18 PM
AX-5 and NP231 Fluid need quick help!!! Pedro7 TJ Wrangler Technical Forum 3 08-03-2008 07:10 PM
D30/D44 Fluid Capacity sb127 TJ Wrangler Technical Forum 4 11-13-2006 01:31 PM
Quick Question: Manual tranny fluid capacity? blackntan YJ Wrangler Technical Forum 4 12-21-2002 11:02 AM
