questions on spacers for tire and wheels - JeepForum.com
post #1 of 3 Old 04-03-2010, 07:37 PM Thread Starter
staufson
1987 YJ Wrangler
I am putting 33's on my Wrangler. I found a sweet deal for the tires and the rims (baja radials) for 500 bucks. However, I am having to order a conversion from 5x139.7 to the Jeeps 5x114.3 pattern. They are asking me about the thickness in which one inch of space is the smallest they have. The rims are 16x10, my question is do I need more space for them cause I might as well if I need to.
Thanks
staufson is offline
post #2 of 3 Old 04-03-2010, 08:02 PM
GilaMtnJeep
GilaMtnJeep's Avatar
If you're goin with 33x12.50's then I believe the backspacing needed is 3.75". Measure the backspacing on the wheels you're getting and you'll know what you need. Probably going to be about 1.25" spacers, if you need them.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 3 Old 04-03-2010, 09:04 PM
wrangler76
I would buy the set... then dismount the tires... Keep the tires..... Sell the wheels and buy the right bolt pattern/offset wheels. Probably cheaper and more effective in the long run.
wrangler76 is offline
Spacers or new wheels? Augy YJ Wrangler Technical Forum 24 08-22-2009 04:53 PM
New wheels and spacers OCBob JK Wrangler Technical Forum 8 03-13-2009 12:48 PM
New wheels or spacers? JeepPirate TJ Wrangler Technical Forum 2 03-30-2008 05:06 PM
Will the stock wagon wheels (15x7) with 31x10.50 tires fit on without wheels spacers? BIGCRAZYBELL TJ Wrangler Technical Forum 4 11-28-2004 01:10 AM
wheels spacers???.... seany425 TJ Wrangler Technical Forum 1 02-13-2004 10:28 PM
