Questions on shackles and winches. - JeepForum.com
post #1 of 4 Old 03-18-2002, 08:57 PM Thread Starter
yj@vt
Hey guys/girls, I'm new here, so first off, nice to meet you all. I had two questions. First of all, is it hard to install lift shackles on front and rear of my YJ. Secondly, my grandfather has an old Ramsey winch on the front of his CJ. Can I make this work on my jeep, and if so, will I have to get heavy duty springs in the front of my jeep or anything. Someone told me I might, as the winch weighs a fair amount. Thats it for right now I guess. If you get a chance check out my webpage. Worst stuck I have ever had. Oh well, later on guys/girls.
Terryyj
1993 Sahara Green
4.0HO (With A/C!!)
Needs Mods:)
yj@vt is offline
post #2 of 4 Old 03-19-2002, 07:52 AM
V8wrangler_idaho
you should be able to make the wench work fine on the front of your jeep. Im sure that they make a mount to mount it up there. You should be fine with the springs that you have up there if it makes is sag some up on the frount you could go with some over load shocks On the frount. or just add a leaf spring to the frount. Both are pretty simple. and on the shackel lift on the back of the jeep pretty simple. Best thing for you to do is buy new bolts for the shackels on the back. Its easyer to cut the bolts off back there then to take it off. but other then that very simple
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
post #3 of 4 Old 03-19-2002, 11:29 AM
PoorFool
I don't know much about the winch, but I do on the shackles.
If they are for lift, don't do it. If you really plan to wheel, and that's all the lift you have, you'll hate them. I had 2" lift shackles on my 94 for 90 days before I rammed one into a whole and bent a spring. I always thought that I was a cautious enough driver to avoid that, but was wheeling in snow and the hole was full of it. Also, if they don't bend your springs, they well drag and catch on every little thing. I had problems making it through obstacles with lift shackles that I had previously conquered easily in stock form. Just my opinion, but I'm sure others share it.
Turbocharged 4.0, 35" Kevlars, 33 spline Detroit D44, 4.88s, heavy foot.
PoorFool is offline
post #4 of 4 Old 03-19-2002, 11:32 AM
PoorFool
Forgot to mention ease of install. If you're going to replace shackles, get the kind that bolt together. The welded ones can be a bear to get over the bushings. I actually ground my bushings down for mine to fit. Then when I went back to stock shackles I had to buy new bushings. That's an easy $75 I didn't really want to spend.
PoorFool is offline
Bought a yj with shackles, questions... yjJeff YJ Wrangler Technical Forum 5 04-05-2009 03:29 PM
Questions on how to order MORE Shackles YJames90 YJ Wrangler Technical Forum 5 04-28-2008 07:13 PM
shackles...a few questions Tim3852 YJ Wrangler Technical Forum 6 03-05-2007 09:29 PM
Few questions about shackles Ryanjeeper YJ Wrangler Technical Forum 5 02-05-2006 10:27 PM
clicking and winches two questions Jeepfreak81 YJ Wrangler Technical Forum 1 06-05-2002 11:44 PM
