Questions on shackles - JeepForum.com
post #1 of 5 Old 10-21-2010, 10:33 AM Thread Starter
07lane40
Okay guys, i have a couple questions.
I am going to get a 2" BDS lift and im wondering about shackles. I am going to get 5/8" boom shackles for the rear to clear the military wraps.
I have the 6 cyl and an old warn winch like the 8274-50 and its a heavy sucker. is it an okay idea to get 1" shackles for the front to level out the jeep?
I guess my actual question is - is it okay to have longer shackles in the front than in the rear? I'm not talking squirrely high but just a little longer to counter the weight over the front end.
or should i just get matching booms in the front?
Thanks!
07lane40 is offline
post #2 of 5 Old 10-21-2010, 10:48 AM
jbeebe
i have never heard of anyone doing that. i would just get matching ones. when I bought my jeep years ago it had a crappy HF winch and a 130lb (no kidding) bumper on the front. even with that it wasn't too noticeable (as far as sagging). so you'll be fine.
jbeebe is offline
post #3 of 5 Old 10-21-2010, 01:08 PM
Treasure
it wont harm anything to have two different sizes, however unless your leaf springs are very worn/weak it shouldn't sag with the new shackles.(because new shackles will change the angle on the springs and put more tension on them hopefully causing them to be stiff enough to stay at the correct height even with the fatty winch)
Treasure is offline
post #4 of 5 Old 10-21-2010, 02:15 PM
monkeyhouse
i just read a thread on the first page today where a few people said they did it.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 5 Old 10-21-2010, 03:24 PM Thread Starter
07lane40
thanks for the help guys, i thought it sounded kinda odd but i would like the the suspension to have as much available up travel as possible without going crazy.
with the stock springs my bumpstops are literally an inch from the axle and its rough. I just want to make sure that i have room to flex up.
07lane40 is offline
bds , boomerang shackles
Bought a yj with shackles, questions... yjJeff YJ Wrangler Technical Forum 5 04-05-2009 03:29 PM
Questions on how to order MORE Shackles YJames90 YJ Wrangler Technical Forum 5 04-28-2008 07:13 PM
shackles...a few questions Tim3852 YJ Wrangler Technical Forum 6 03-05-2007 09:29 PM
Few questions about shackles Ryanjeeper YJ Wrangler Technical Forum 5 02-05-2006 10:27 PM
Questions on shackles and winches. yj@vt YJ Wrangler Technical Forum 3 03-19-2002 11:32 AM
