questions on lockers - JeepForum.com
post #1 of 8 Old 02-04-2002, 09:36 PM Thread Starter
iamthemellowman
I bet there's a faq on this somewhere...or there should be. Got real stuck the other day, and killed what i had left of the stock lsd sheeit. Now, I've been reading,, and I hear the detroit locker is not good for street use? Hey i don't mind if my butt wiggles when i give it the go juice.. whats the characteristics that make this 'bad' for street use? meaning, i know what a locker does, but what does it mean in the way the jeep rides/drives etc.
Ok, so I'm really not interested in any type of lsd with clutches. .but what about the ones with gears? are they the in-between of clutches and full on lockers? what's a good quality unit?
Now, another thing, I've notice the price is about 450 or so to 650 for various diffs,,,
I saw this ad in quadratec for the 'evolution series super 35 rear axle kit' This comes with beefed axles, new bearings and seals, shims, new wheel studs... and a detroit locker!!! ..though it calls it 'an exclusive detroit locker' so not sure what that means. all that for 900 bucks.. hey not too shabby i'm thinking? what do y'all think of that?
hmm tough decision ...I don't think i'll be able to really beef the jeep out for several years as i'm probably going to be in college (grad) soon. So, i'm just looking for something i can use with the stock axle housing and get some reliable performance...
it's soo not fun with an open diff!
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #2 of 8 Old 02-04-2002, 09:48 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
This is what I use - Costs around $360 and utilizes your stock carrier.
Powertrax
You will get many opinions on lockers so be prepared!
BTW - the prices on the site I posted seem high - I'm sure you can get it cheaper somewhere local to you.
Steve
OldJeepguy is offline
post #3 of 8 Old 02-04-2002, 10:15 PM Thread Starter
iamthemellowman
mmm 'designed for the do it yourselfer' hehe, pretty slick. I need to determine exactly what my diff is.. i'm pretty sure it was lsd before..
how was the install? any noticeable amounts of backlash?
post #4 of 8 Old 02-04-2002, 10:29 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Mine is installed in an AMC 20 open carrier and was a real pain. We had to remove the carrier and the ring gear to get the cross shaft out. I've heard this is not typical with other diffs - in fact a couple guys I know have them installed in the D/35 diffs and said the install was really easy.
I've found mine to be a bit noisy on the road, again I'm told this is not typical. I am happy with the locker so far...
Steve
post #5 of 8 Old 02-04-2002, 11:18 PM
dennisuello
dennisuello's Avatar
you have Dana 35 rearend, the install shoud be pretty easy (no need to pull the carrier out).
LockRight lockers are pretty good (for $230 that is. )
dennisuello is offline
post #6 of 8 Old 02-05-2002, 01:52 PM
bobznew
I use this setup with my YJ:
Lock-rite in the rear
No-slip in the front
Could not ask for anything better. Amazing traction, and very little handling problems.
This was the setup that the Powertrax tech. assistant recommended for me.
HTH
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #7 of 8 Old 02-05-2002, 02:36 PM
moabe
if you are smart hit the cowtown jeep forum and pick up the detroit ez locker for $100 to go in your d35...you get the normal swirve at accelleration and decelleration. but for $100 ya cant beat it
i am only half the man i used to be, which still makes me twice the man that you are now
moabe is offline
post #8 of 8 Old 02-05-2002, 04:47 PM
Tailgummer
Any true auto locker such as Lock Rite, Detroit with have the same handling characteristics. ie the shorter your wheelbase the more noticable it is. My old M38A1 with a detroit would almost change lanes with rapid throttle movements. A YJ is not nearly as bad, but with a D35C rear axle, using a Detroit would be overkill. The housing and axles are not that strong. If you plan to keep the D35C I'd suggest either a Lock Rite, EZ locker or similar. They will hold up as well as the D35. If you can go a few more bucks I'd suggest pulling the D35 and installing a '95 or newer Ford Explorer 8.8". You get disc brakes and a much stronger axle. You can then install an ARB (my preference) or a Detroit. The 8.8 conversion is simple and the prices can still be reasonable but are going up as the word gets around. Don't put an ARB in a D35C, It will not hold up under any significant use. The D35C housing flexes too much for the ARB. ARB has beefed up their unit but it still does not survive well in the flexible housing.
Just my .02
Good Luck
Chuck
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
Few questions about Rubicons diff/lockers sgmongoose TJ Wrangler Technical Forum 3 03-15-2009 09:55 PM
A few questions about lights, lockers, and suspension simplybao TJ Wrangler Technical Forum 2 02-04-2008 06:54 AM
Questions?.......OBA, Lockers, & Gears? MDC3 TJ Wrangler Technical Forum 11 02-22-2007 06:30 AM
Lockers and Ford 8.8 questions Weekender1969 YJ Wrangler Technical Forum 18 08-18-2006 10:37 PM
Couple of questions about lift and lockers 01TJ TJ Wrangler Technical Forum 1 04-28-2004 05:29 PM
