Questions on how to order MORE Shackles - JeepForum.com
post #1 of 6 Old 04-27-2008, 05:02 PM Thread Starter
YJames90
YJames90's Avatar
Im looking on the MORE web page and Im a bit confused
I want the boomerang 5/8 inch lift shackles for the front and rear.
I currently have the 4wd hardware 2" suspension lift military wrapped springs with stock shackles
The order form wants me to enter a spring with . I measured the springs and got 2 1/2 inches but at the part where the shackle attatches its only 2 1/4 inches. do i tell the its a 2 1/2 inch wide spring?
Also they want to know the spring eye inside diamater. The parts list that came with my lift says the spring eye bushings OD is 1.5 inches so this means the the spring eye ID must be 1.5 . Am I correct?
The last choice is bolt size , the first choice dosent mention a size so am I to assume this is the stock bolt size that I am using since i have the stock shackles?
The instruction mention that the shackle end of the spring uses 1/2 " ID sleeves So I beleive I am to order using 1/2" not 9/16"
The other bolt size is 9/16"
Thanks for your help
Are these only sold by the manufacturer?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #2 of 6 Old 04-27-2008, 05:59 PM
darioc
I would pm "Fullsizexj" I bought 2 sets from him and he was very helpful. Tell him what kind of springs you have and he'll help you out. I think basically they wanna know whether or not you have military wrap.
darioc is offline
post #3 of 6 Old 04-28-2008, 03:28 PM Thread Starter
YJames90
YJames90's Avatar
I bought front and rears from Fullsizexj today.. Thanks. I will post pics after the install
YJames90 is offline
post #4 of 6 Old 04-28-2008, 04:02 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Call them. They are very friendly and will fix you right up. I never order off the site. I always call and get it straight from the horses mouth. This goes both ways.....as then they can talk with you and get you what you need the first time.
Tomb Raider is offline
post #5 of 6 Old 04-28-2008, 04:26 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i second that...
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #6 of 6 Old 04-28-2008, 07:13 PM
Fif28
I second this, I've called and they are great! They'll be getting some more of my hard earned money for sure!
Fif28 is offline
Before I order my RC lift, a few questions. Escape311 TJ Wrangler Technical Forum 2 02-25-2009 08:10 PM
About to order 4dr few questions? CJATE JK Wrangler Technical Forum 0 02-21-2007 09:02 PM
Shackles... Looking To Add To Quadratec Order... NIUPonyBoy YJ Wrangler Technical Forum 9 05-30-2005 11:05 PM
MML Questions Before I Order treehugger TJ Wrangler Technical Forum 9 03-22-2005 07:03 PM
upgrade questions before I order hardwarp TJ Wrangler Technical Forum 4 09-02-2004 09:50 AM
