Questions About Replacing Cat - Page 2 - JeepForum.com
post #16 of 21 Old 04-22-2010, 07:50 PM
dadstoys2
1987 YJ Wrangler
I had a complete exhaust 2.5" pipes with highflow cat and flowmaster for under $275. The cat was $65 and the local shop welded it all high and tight.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #17 of 21 Old 04-22-2010, 08:05 PM
dadstoys2
1987 YJ Wrangler
~Rich
post #18 of 21 Old 04-22-2010, 08:36 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by ROADDOG516 View Post
I just replaced mine with a flowmaster high performance cat that was a bolt on. After removing the skid plate I supported the tranny and tc with jack stands. (note: becareful with the transmission stabilizer stud if its old it could break , mine did got another one with much needed poly bushings for $11.00 from 4wd.com) I originally thought my YJ still had the factory cat which was welded on, I grinded off this weld so that I didnt have to cut the pipe (i didnt want to shorten my pipe), after cleaning up the pipe I bolted on my new cat and clamped everything down dam tight. The only pain was that the "direct fit" cat had a slightly larger diameter outlet than my muffler would recieve so I used a muffler pipe expander and opened it up. Buttuned it all back together and couldnt be happier with results. Just by replacing my cat I got back my 5th gear and have great fuel economy even with my 4banger and 33's. As I said I thought I had the factory cat but when I brought it to the scarp yard the guy showed me that this thing was a aftermarket which explains why it was welded on. O well he still gave me five bucks better than zero. good luck.
do you have tha part number for that stabilizer stud..? thanks
NHfireLJ is offline
post #19 of 21 Old 04-22-2010, 09:55 PM
mongowo
mine was both, it had a flange that slide inside of the other one, and then clamps overtop of the joint....we had to use a propane torch to warm em up and expand the rust and corrosion before we were able to pull them apart!!
mongowo is offline
post #20 of 21 Old 04-22-2010, 10:58 PM
mongowo
Originally Posted by Couchrider View Post
Are the tubes joined by a flange or exhaust clamp?
mongowo is offline
post #21 of 21 Old 04-23-2010, 09:15 AM
ROADDOG516
ill get u the part # in a few hrs goin to bed
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
Questions about replacing 4.0L 94YJ Exhaust Manifold biasdesign YJ Wrangler Technical Forum 3 07-15-2009 12:30 PM
Replacing transmission - questions! Buford TJ Wrangler Technical Forum 2 09-20-2008 01:13 PM
Replacing Radiator Have Questions!! SEMO 95 YJ YJ Wrangler Technical Forum 5 03-07-2008 06:02 PM
Replacing stabilizer link bushings/Questions David R TJ Wrangler Technical Forum 0 11-18-2007 04:47 PM
Thinking about replacing XJ with YJ, questions? Antelope YJ Wrangler Technical Forum 15 10-11-2004 10:45 AM
