Questions about mirror relocation brackets - JeepForum.com
post #1 of 12 Old 08-08-2011, 01:35 PM Thread Starter
SquidsYJ
These things seem straight forward and simple. Get the right one for your year/model Jeep. Bolt it on. Move your existing mirrors to the brackets, and off your doors come. Cake, right? Not for me.
The only problem seems to be that most of the brackets marketed for a YJ like this one from rugged ridge. Don't fit. I have a pair sitting on my kitchen counter to prove it. Normally, I figure that the picture is some canned generic picture used to give an idea of what's inside the box and the same picture is used for all models even if they are different. This picture is spot on with what I received though.
http://www.jeep4x4center.com/mirror-...lack-8685.html
The holes on these "no drill" brackets do not even line up with either of my preexisting windshield brackets.
I looked though the other YJ mirror bracket offerings at Morris, and all brackets but one looked to be identical. The one that was different actually looks like it should be a perfect fit.
http://www.jeep4x4center.com/warrior...t-war1505.html
Did I get the wrong brackets, am I just being really obtuse and missing something, or are there different brackets for different years?
I just want to add that Virginia requires at least one side view mirror, or this wouldn't really be an issue.
SquidsYJ is offline
post #2 of 12 Old 08-08-2011, 07:34 PM
phil1330
1964 CJ5
Call morris 4x4 up and talk to someone there. They are more than willing to help you out with this. You may of recieved the wrong parts.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #3 of 12 Old 08-09-2011, 12:49 PM Thread Starter
SquidsYJ
OK. So I feel silly. I was gonna call Morris today when I got home. When I pull into the parking lot, I notice a doorless YJ. Thinking back on it, I probably looked silly as I walked over to it muttering about mirrors and brackets under my breath. I probably looked even sillier when the lights went off and I realized that I had the right brackets and was trying to put them in the wrong place.
Now I need to remove the CJ style mirror mounts and get these installed and my mirror relocated.
If anyone needs/wants the CJ style mirror mounts, let me know and I can get them in an envelope and in the mail in relatively short order.
SquidsYJ is offline
post #4 of 12 Old 08-09-2011, 05:42 PM
phil1330
1964 CJ5
Nice!
phil1330 is offline
post #5 of 12 Old 08-09-2011, 05:51 PM
mrmark
They fit like this. You will have a hard time seeing the passenger side one unless you find a mirror that sticks out further, and if you put a 1/2 door with 1/2 soft top door you won't see it at all.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #6 of 12 Old 08-09-2011, 09:46 PM
bdheaton
Junior Member
Since I'm in the middle of putting mine on right now, let me just say...
@#$%#$^#$%&#$%&$#%& TORX BOLTS!!!!!
bdheaton is offline
post #7 of 12 Old 08-09-2011, 10:26 PM Thread Starter
SquidsYJ
Thanks, that saves me from having to find a replacement for the passenger side mirror that isn't there. The YJ has good enough visibility that I don't usually need a mirror on the passenger side, but sometimes those dang chrome lights on the windshield brackets fool me into thinking they're a mirror at first glance.
One of the PO's hooked me up by removing those specific torx bolts and installing some stainless hex head bolts and what looks like a CJ style mirror bracket.
SquidsYJ is offline
post #8 of 12 Old 08-09-2011, 10:54 PM
stcarter44
You can say that again.. Im going to replace all mine with just a regular phillips head screw
stcarter44 is offline
post #9 of 12 Old 08-10-2011, 04:13 AM
mrmark
remember by law you must have 2 mirrors on a vehicle.
I need to have the passenger one because for some unknown reason I can't get a rearview to stay on my windshield, I have tried to glue one on 4 times but the first bump and they come down. (Yes, I do know how to do it I have done it a hundred times on other vehicles and it always works on them.)
mrmark is offline
post #10 of 12 Old 08-10-2011, 07:08 AM
qlfarm
I have the crappy door mounted small mirrors on my full steel doors. Is there a larger option that will replace these and use the same mounting holes? I hate to have to redrill different holes for these.
If I go to the windshield bracket mounts is there a blank plate I can use to block off the old mirror mounting holes or do I have to weld them closed to keep water out of the door?
See ya,
Pat
qlfarm is offline
post #11 of 12 Old 08-10-2011, 01:35 PM
mrmark
See ya,
Pat
You could just bondo or fiberglass resin the small holes since you won't be using them again.
mrmark is offline
post #12 of 12 Old 08-10-2011, 03:57 PM Thread Starter
SquidsYJ
See ya,
Pat
I haven't seen any blank plates, but you could try using button head type screws and RTV to seal up the holes on your doors. It will be water proof and non permanent if you ever decide to go back.
SquidsYJ is offline
i got mirror relocation brackets but can't see passenger mirror thelazerviking TJ Wrangler Technical Forum 12 07-21-2015 08:38 PM
Mirror relocation brackets jameskehler YJ Wrangler Technical Forum 5 09-16-2008 12:55 PM
mirror relocation brackets- help paroxysym YJ Wrangler Technical Forum 8 06-22-2006 01:05 PM
Mirror relocation brackets Spiderman TJ Wrangler Technical Forum 15 04-19-2004 07:15 PM
Mirror Relocation Brackets rockhopper TJ Wrangler Technical Forum 9 08-25-2003 03:10 PM
