Questions about lifting my YJ - JeepForum.com
post #1 of 11 Old 01-20-2002, 09:58 PM Thread Starter
JeepYJ295
Hey Yall, I am installing 3" leaf spring blocks (bringing the leaf springs from under the axle to on top of the axle then blocking them up 3") and a 3" shackle lift, and will be running 32x11.50x15's. Do I need to make any hose extensions, brake extensions, or any adjustments at all or will i be fine? Thanks!
'94 YJ, black, 3" lift, 31x10.50x15, 2% window tint on all windows, Flowmaster 40 muffler, huge sound system with JL 12" W0 & Rockford amp, Viper alarm, CB/PA, Lights, aftermarket carpeting kit & very nice interior! Bought it for $1200 & my girlfriend loves it too! :)
JeepYJ295 is offline
post #2 of 11 Old 01-20-2002, 10:14 PM
West
I'm not real familiar with the math involved here but I thought I read that SOA gives you 4-5 inches of lift. Plus 3 inch blocks between springs and axle, and 3 inch shackle lift? That seems to add up to 10 or 11 iches of lift? I may be wrong but it sounds like everything conected to axles will need modifying.
West is offline
post #3 of 11 Old 01-21-2002, 12:47 AM
Billy Badass
I have to agree with west, but I most say that your jeep will look really funny with only 32, I would go with at least 35's. Drive shaft, brake lines, stearing, track arm, both drive shafts, dransfer case drop, and you will have to shorten the rear output shaft from the transfer case. But I must say that if you choose to lift your jeep this way it won't last long, I know it's cheap, but not very evvective. With the shackle lift you will actually have about the same ground clearance as you do stock. Plus bumb stear will be horrible, and your stability will be gone, to high with to bad of suspension, with to small of a tire. I'm not trying to put you do, please don't take it that way. Just trying to give you the best and safest advide that i can. Hay but if you accept the risk and you like it thats all that matters.
If it ain't broke you ain't play'n hard enough.
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
post #4 of 11 Old 01-21-2002, 12:31 PM
RatherBeJeeping
What about the amount of spring wrap you'll get with that set up?
John
95.5 YJ with "stuff"
RatherBeJeeping is offline
post #5 of 11 Old 01-21-2002, 12:44 PM
RockJeep
Motobilt.com
RockJeep's Avatar
WARNING!!! WARNING!!! WARNING!!! Blocks are dangerous!!! Especially in the front. DO NOT USE BLOCKS!!! also 3" shackle lift is not a good idea either. i'd stay at a maximum of 2.5(personally 1" is as high as i would go.) causes caster problems in the front, which in turn causes handling problems. a spring over(springs on top of axles will net you 5-6"s of lift. this is more then enough for 32's more like 33-35's. If i were you i'd get a 1-1.5" shackle and maybe a 1-2" body lift and run your 32's. or a 3-4" lift kit.
good luck,
bob
P.S. BLOCKS ARE DANGEROUS
1998 Jeep TJ on 37's, locked, long armed etc
Sales Manager at
RockJeep is offline
post #6 of 11 Old 01-21-2002, 01:42 PM
AJ
Go ahead with the lift and sell tickets. A trip around the block will be more exciting than anything at the amusement parks. Seriously, 2 1/2" lift will clear 32's really easily. Stock will clear 31's without too much rubbing.
AJ is offline
post #7 of 11 Old 01-21-2002, 02:47 PM
Brendan
Thats crazy!!! you'll kill yourself. Blocks are no good, 3" of shackle lift will screw up the sterring system, and I doubt you know much about SOA's or you would know not to do that other stuff. YOu should probably buy a 4" suspension lift and a 1" body lift. That will be more than enough to start your on your way.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #8 of 11 Old 01-21-2002, 05:40 PM
PuebloIV
All I've ever read about blocks have the same message...DON'T.
PuebloIV is offline
post #9 of 11 Old 01-22-2002, 03:16 PM
rollinashortysahara
dude if you wan that much lift start soa , then go bigger axles then lift springs if you need to be that big needless to say this is expencive but you won't die when yo prss the brakes and your axles rollover cause of 3inch lift blocks
rollinashortysahara is offline
post #10 of 11 Old 01-22-2002, 05:29 PM
Tonka
2015 JK Wrangler
DANGEROUS, and in quite a few states, ILLEGAL
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #11 of 11 Old 01-22-2002, 09:10 PM
YJ boy
I agree with rock and billy. I done a soa on my 90 YJ it liftef it up 5 inches I have a good write up about it if you need it just e-mail me. I also put 33's and there is still room for at least 35 I will send you a picture of it if you need. and last but not least DO NOT USE BLOCKS !!!!!!!!!! [img]null[/img]
YJ boy is offline
Questions on lifting my tj jacksonjeeper TJ Wrangler Technical Forum 3 01-13-2009 08:21 PM
Lifting 97 TJ - questions adriel TJ Wrangler Technical Forum 3 03-05-2008 09:56 AM
Lifting questions... colinxmurphy TJ Wrangler Technical Forum 14 08-28-2006 01:42 PM
Lifting Questions Bakalaho YJ Wrangler Technical Forum 2 05-15-2005 08:45 PM
Lifting Questions biffstephens TJ Wrangler Technical Forum 4 09-26-2004 04:26 PM
