Question on YJ Engine mounts? - Page 2 - JeepForum.com
post #16 of 22 Old 07-11-2013, 08:55 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
You will find my answer on my tool box. It's a Yellow Oval decal.
Do It once and be Done !
Sent from AutoGuide.com App
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #17 of 22 Old 07-12-2013, 10:39 AM
Randonexplosion
Randonexplosion's Avatar
Brown Dog mounts are very nice, but M.O.R.E. makes a great product as well.
Randonexplosion is offline
post #18 of 22 Old 07-12-2013, 11:42 AM
bigsquat
there so easy to make why spend the $90. even if you dont have a welder u must know someone with one who could spend 5 minutes running a few beads. or its a great excuse to buy one. even a stick welder can be bought used for less than the new mounts cost. if u own a jeep its kinda manditory to own a welder!
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #19 of 22 Old 07-12-2013, 12:56 PM
UZI4U
Kinda off topic...are both of the factory mounts identical in size or is one larger that the other? I got a new set and one is wider than the other where the engine would bolt to the mount.
MCLMM
UZI4U is offline
post #20 of 22 Old 07-12-2013, 02:41 PM Thread Starter
VenomousMaximus
Is the manual trans mount and the automatic trans mount the same?
VenomousMaximus is offline
post #21 of 22 Old 07-12-2013, 02:56 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
I ran into the problem when I installed new factory mounts from autozone. I took a grinder and shaved off what I needed.
I'd imagine the mounts are the same engine wise despite the transmission. No reason to change one to the other.
Michaelgoesrawr is offline
post #22 of 22 Old 07-13-2013, 11:04 AM
UZI4U
I was considering that. I got my set from Q-tec because I needed the transmission mount and I figured I may as well change them out too.
MCLMM
UZI4U is offline
