Question on YJ Engine mounts? - JeepForum.com
post #1 of 22 Old 07-09-2013, 11:13 PM Thread Starter
VenomousMaximus
I need to order Engine mounts, mine are in really bad shape.... My question is should I order a 1" lift mount or just go with 0" factory height... Also what do y'all think of the M.O.R.E BombProof mounts? Or should I just go with the Energy Suspension poly's.... Thanks for the help.... Any suggestions will be greatly appreciated.
VenomousMaximus is offline
post #2 of 22 Old 07-09-2013, 11:26 PM
rshbutch
I would go with brown dog mounts
rshbutch is offline
post #3 of 22 Old 07-10-2013, 12:04 AM Thread Starter
VenomousMaximus
Brown Dogs mounts look top notch! I answered a lot of my own questions just by visiting his site...lol. Hmm... now any suggestions on a Transmission mount, since it says to replace them together? Thanks again.
post #4 of 22 Old 07-10-2013, 12:37 AM
Michaelgoesrawr
Brown Dog is where id put my money. Tim is a really great guy.
Michaelgoesrawr is offline
post #5 of 22 Old 07-10-2013, 08:07 AM
bigsquat
if you dont change them together you might get cracks in the mounts . almost for sure if you were to upgrade the tranny mount with poly and not the motor mounts like i did. they have to be the same type of material because they flex different otherwise and something has to give. i made my own motor mounts to match my upgraded tranny mount.
http://i393.photobucket.com/albums/p...rmounts003.jpg
<a href="http://s393.photobucket.com/user/big...ts006.jpg.html" target="_blank"><img src="http://i393.photobucket.com/albums/p...rmounts006.jpg" border="0" alt=" photo motormounts006.jpg"/></a>
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #6 of 22 Old 07-10-2013, 08:14 AM
taylor797
I have brown dogs in mine with an energy poly tranny mount and they work great
taylor797 is offline
post #7 of 22 Old 07-10-2013, 09:47 PM Thread Starter
VenomousMaximus
Nice mounts Bigsquat, you got a materials list to make the mounts?
post #8 of 22 Old 07-10-2013, 10:10 PM
bigsquat
Originally Posted by VenomousMaximus View Post
Nice mounts Big squat, you got a materials list to make the mounts?
the round pipe is 1-1/4 schedual 80. the poly bushings are from the big eye on a yj leaf spring. the rest is 1/4" flat bar. i bought a new stock motor mount to copy. i was able to get the pictures up. i think the flat bar is 2" wide
motor mounts 003.jpg   motor mounts 004.jpg   motor mounts 005.jpg   motor mounts 006.jpg   motor mounts 007.jpg
bigsquat is offline
post #9 of 22 Old 07-10-2013, 10:39 PM Thread Starter
VenomousMaximus
Very nice!.... Thanks.
Its amazing what you can do with a welder and the know how.
post #10 of 22 Old 07-11-2013, 07:44 AM
az_zoner
I'm going to recomend Brown Dog too. I got my BD motor mounts 2nd hand. I wanted to put the rubber bushings in them as they came with poly. I called Tim and ordered them. So the next day Tim actually shows up at my house to make sure I was getting the right ones. Un-Real customer service!!
The mounts install was pretty easy, but my engine was out on a stand when I put on the bracket on.
cb
az_zoner is offline
post #11 of 22 Old 07-11-2013, 04:33 PM
dtn8tr
Just installed my BD mounts also along with Energy Suspensions poly tranny mount. A+
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #12 of 22 Old 07-11-2013, 04:39 PM
gunshw301
Originally Posted by dtn8tr
just installed my bd mounts also along with energy suspensions poly tranny mount. A+
x3
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #13 of 22 Old 07-11-2013, 05:32 PM
StanF
I have Brown Dog 1" mounts - they are very strong, but they transmit more vibes than the stock mounts. Just be aware of that. I started with the poly bushings and then bought and installed the softer rubber bushings.
StanF is offline
post #14 of 22 Old 07-11-2013, 06:32 PM
gunshw301
I am/was the same. I also went 1inch lift and rubber bd mounts. When brand new there were very rough. Bd warns about having them too tight and I thought that was my issue. I double checked but the bolts were fine. Drove it a bit and now they are much better. I suppose they have just settled in a bit, still a little more than than my stockers, but considering how bad the rust was I suppose that helped dampen them as well.
post #15 of 22 Old 07-11-2013, 07:08 PM
voz
I was given a set of Prothane Poly inserts for stock mounts, have not installed them yet, but I hope they work out..
Also got poly trans mount...
VOZ™
voz is offline
