question for ya'll - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > question for ya'll
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 09-22-2001, 04:13 PM   #1
red wrangler renegade
question for ya'll
i've got a 91 yj and my headlights will go on and off when i'm driving at night. the hazards, brake, running, and instrument panel lights still work. i have kept my fog lights off for a couple of months because one blew out, so i don't know yet if they would stay on. any suggestions or should i take it to be tested?
red jeep club member #61
red wrangler renegade is offline   Reply With Quote Quick reply to this message
Unread 09-23-2001, 01:48 AM   #2
RFWrangler
hmmm, now thats an interesting problem. Have you messed with any of the wiring recently? like installed any new electrical components? (anywhere in the Jeep) like an alarm, Cb, stereo anything like that? If so, you (or the installer if it was done by someone else) might have accidently spliced into something they shouldn't have. let me know if anything was put in recently so I can get a better Idea of what you should look at.
My 92 YJ
Clarion BD216, RF 200aIV, Clarion APA2030, RF HE2 12's, Rf 4x6's, RF 1" Tweets, Eclipse EUU-1300, Aura Bass Shakers Security: Clifford Power: Optima Yellow top,Thrush turbo 2 1/2" Exhaust, Radio Shack Sport CB, 102" whip antenna, Dual tips on Exhaust, K&N custom intake, KC Lightbar, 4 KC Daylighters.
Scored a 139 on the Jeep Rater.
RFWrangler is offline   Reply With Quote Quick reply to this message
Unread 09-23-2001, 06:16 AM   #3
as far as i know, nothing has been done recently. the last time anyone has messed with any wiring was when my mom cut the wires that were connected to the inside lights because they stayed on when she would take the doors off, but she did that years ago.
Unread 09-23-2001, 09:19 AM   #4
tonyxjyj
Check your Hi\Lo beam switch. my 87 had the same problem.try to switch the hi\lo,s on or off when it does act up.I changed the switch out problem solved.
tonyxjyj is offline   Reply With Quote Quick reply to this message
Unread 09-26-2001, 11:12 PM   #5
GothicJeep
I had an 88 yj that did that (my first jeep...ahhhh, memories...). I feel for ya - pretty darn scary when you're driving down a dark road (or trail) and your suddenly blind, huh?
You might want to check the connectors that plug into the back of the halogen lights. I don't know where your at, but I'm from Cleveland and we get pretty harsh winters. Mine had a lot of corrosion on them from road salt and it interfered with the connection. A little work with some steel wool and/or a wire brush solved the problem right away. Hope this helps...
JeepGeek Offroad Member v4.0
'Blue Zombie' (My 2002 TJ SE)
30x9.5 Hi-Tec Muds, Olympic Dave's Rack, and a BUTTLOAD of tow hooks...
My blog! Dr. Zombie's Midnight Theater or Terror
GothicJeep is offline   Reply With Quote Quick reply to this message
Unread 09-27-2001, 09:33 AM   #6
Kev
Master of the Obvious
Kev's Avatar
Along with checking the hi/lo beam switch, you may want to replace the main head light switch. Had the head light switch on my truck go out once, did the same thing. The marker and dash lights will still work because there are two different positions on the switch. Good luck
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline   Reply With Quote Quick reply to this message
Unread 09-27-2001, 09:45 PM   #7
NaeKid
JF Administrator, eh?
NaeKid's Avatar
While you are cleaning the headlights, make sure you use some dielectric grease on all the contacts. Winter salt and snow and dirt plays havoc with electrical connections! Use it also on your sparkplugs as well .. and anywhere else you feel like using it.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver 2006 TJ Unlimited, zombie ready as the daily-driver
- - - - - - -TEOTWAWKI- - - - - - -
NaeKid is offline   Reply With Quote Quick reply to this message
