Question in upgrading gears ratio - JeepForum.com
post #1 of 13 Old 04-13-2013, 05:55 AM Thread Starter
Ansary
1996 YJ Wrangler
Hi Jeepers,
I have a YJ 95 6 cy 4.0L. I am in process of upgrading the gears ratio to 4.1 I ordered ring and pinion for both the front and rear deferential. The front ring and pinion are 41/10 and the rear is 37/9 the gear ratio will be 4.1 and 4.11111. Is the 0.11111 difference normal or it can cause a problem?
Ansary is offline
post #2 of 13 Old 04-13-2013, 06:11 AM
1998zj
It will be fine, all of the Jeeps out there running that ratio are like that.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 13 Old 04-13-2013, 06:24 AM
Siva283
Most 4wd vehicles are like that cause the size of the ring gear is a little different between the axles. Yoir good to go
Sent from my Galaxy S3 using JeepForum
Ask me how I know...
Siva283 is offline
post #4 of 13 Old 04-13-2013, 08:44 AM
RockWoRM
RockWoRM's Avatar
You're likely to have more than 0.11111" of difference between the front and rear tires just from wear.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #5 of 13 Old 04-13-2013, 09:12 AM
rykemc
You will have to change the carrier as well sir.
rykemc is offline
post #6 of 13 Old 04-13-2013, 12:50 PM Thread Starter
Ansary
1996 YJ Wrangler
I can't understand why should I change the carrier?
Ansary is offline
post #7 of 13 Old 04-13-2013, 12:53 PM
pete1991YJ
The difference between the front and rear ratios is normal, and it is nothing to worry about. If your old gears were less than 3.73 ratio then you will also need new carriers to match the new gears - they are a different size. Most Dana brand axles are designed this way, the change in carrier size occurs at 3.73 ratio.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #8 of 13 Old 04-13-2013, 12:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The ring gears only fit a certain number of ratios and they change slightly in size. You'll notice a 4.88 pinion is tint just achieve that gear ratio. Because that's what it is. The ratio between the ring and pinion gears which transfers to torque to the wheels from the transmission which also has its settings called gears.
By the by, unless you're installing full carrier lockers, find a set of used axles and skip the expensive regearing process. Trust me. I've been there and done it. And sticking to the Dana 35 in the rear?
Luck Favours The Prepared
Anticanman is offline
post #9 of 13 Old 04-13-2013, 12:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pete is right. The break between the Dana 30 and 35 is at different places though. You can go up to 3.54 on the 30 and up to 3.73 on the 35 before you need to swap carriers.
post #10 of 13 Old 04-13-2013, 01:15 PM
pete1991YJ
OOps my mistake, I thought thy were in the same place. There *is* a carrier size break though.
post #11 of 13 Old 04-13-2013, 01:25 PM
rykemc
Per his thread on wrangler forum he is running 3.07 gears thus the need for new carriers front and rear. I told him that over there as well.
rykemc is offline
post #12 of 13 Old 04-13-2013, 01:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A very sincere kudos for following up.
post #13 of 13 Old 04-13-2013, 01:44 PM
rykemc
Lord knows I have made enough mistakes with my own jeep, hate to see anyone else doing the same. And thank you sir.
rykemc is offline
