Question for those who have removed a 3" body lift from an auto. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Question for those who have removed a 3" body lift from an auto.
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 10-10-2007, 07:58 PM   #1
hogzilla
For those who have done it, did you have any problems with the shift linkage ?
I loosened the upper shift rod bolt to allow for downward movement of the rod but it seems there is a bracket that is causing some trouble.
One side is bolted to the engine block and the other to the tub. I haven't seen any brackets included in the kits, so I don't know if the bracket is stock or not. Either way, the " bellcrank" rod is not level. It's 3" higher on the engine side and has pulled out of the support bearing, not allowing me to shift.
Do I need an oem bracket ?
'94 4.0 auto, Rubicon Express 4", 32x11.5 BFG AT, Herc'd, other stuff.....
hogzilla is offline   Reply With Quote
Unread 10-11-2007, 06:51 AM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have heard of adjustment brackets for the auto and tall BL's but have never seen one personally. I would definatly say if you do not have the origional bracket then that is your problem. You need a stock bracket.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
