Question for those that have the driver's side lean.
| View Poll Results: Is you Jeep lower on the driver's side and what do you have for trackbars? | |||
| Yes it leans. I have both front and rear trackbars. |
3 | 21.43% |
| Yes it leans. I have only a front trackbar. |
4 | 28.57% |
| No it doesn't lean. I have both front and rear trackbars. |
4 | 28.57% |
| No it doesn't lean. I have only a front trackbar. |
3 | 21.43% |
| Voters: 14. You may not vote on this poll | |||
#16 | |
Jeep parking ONLY
I had a lean....It was drivers rear.
Very noticeable when I first got the jeep...it had stock configuration except for springs and shocks. I first pulled the rear track. No change. Then I pulled the front track. No change. I went on to pull the sway. No change. There was improvement when I installed some MORE 3/8" greasable booms After swapping out the D35. In this process I removed all the rear spring hardware and shocks etc...and lubed them up. After this treatment It only sagged about half as bad. The final fix has been (so far) RE 4" extreme springs....and all that other good stuff I already installed B4.
-NorthJeep - >> Just Enough Essential Parts RED Jeep Club member - YJ Club - 258's Unite |
#17 |
I lean to the front drivers side. I have no swaybars or track bars. I have a RC 4" lift.
#18 |
Ive run RE and two sets of Superlift springs and have never had an issue with a lean. I run no trac bars but do run a sway bar with discos. The most common link with the "lean" here seems to be RC springs.
Your limited slip differential sucks. |
#19 |
I lean on the rear passenger side.. about 1 inch lower... compensates a little when I am in by myself..
Are the springs the same all around? I seem to recall the springs having a + and a - marked on the springs...
#20 |
I have no lean with my RC 4" lift, no rear trackbar
'89, 4.2, NUTTERED, Team Rush, 4" lift, 1"BL, 1"MML, Flat belly skid, SYE, CV Driveshaft,
35 x 12.50s, XRC8, 150w KC's, Herculined, Tauras Elec Fan, Dual Batteries, 1" shackles & Soft Top for the summer, TJ flares. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
