Question and a Thanks - JeepForum.com
post #1 of 4 Old 08-10-2013, 04:23 PM Thread Starter
bigbossd1030
Okay, so first off I would like to thank Magatetzz for the amazing deal he gave me on an ATK remand engine. I truly do appreciate what you did tremendously.
Now here is my question. The engine I got from Magatetzz today came with most everything for it. From the clutch to a brand new Rad. There are a few things that aren't there, but I have most of those available. Anyway, I bought an engine stand for this project and I am unsure on the bolt sizes I need for it. I have a picture off of google that shows the same location I want to bolt mine to. If anyone knows the bolt sizes that would be awesome. I believe they belong to the bellhousing, but am unsure.
I know what you are thinking, why not just try a couple bolts. Well the engine is now about an hour and a half away from my house. Its at the farm. So I want to make sure I have the right ones. Or a close size to start.
Also, this engine was intended for a 99TJ, will the intake manifold work with my YJ? It has the throttle body on it still. Can I use the one I have on my YJ now? Or do I need to swap my manifold and TB?
Oh and its a 4.0
Thanks in advance for any help with this.
And thanks again Magatetzz. I don't want to use your real name.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #2 of 4 Old 08-12-2013, 09:56 PM Thread Starter
bigbossd1030
Bump regarding my intake manifold question.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #3 of 4 Old 08-13-2013, 08:08 AM
jokerchief462
Bell housing bolts is all I used on a 2.5L.
The intake should fit and any differences should be for anything like attaching accesories. I would definetly fit check it and see if that is a go.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 4 Old 08-13-2013, 08:22 AM
jsawduste
2006 YJ Wrangler
The three top bolts are 3/8-16 and the two bottom ones are 7/16-14.
New intake will physically fit but the new TB MAY have different connectors (electrical). No reason not to reuse your YJ TB. Clean it up good paying attention to the IAC port/seat. Where your going to maybe have heartburn is the power steering mounting and the intake. here are a couple different mounts out there and you may have to swap a couple parts. Google is your friend here.
jsawduste is offline
