Question regarding front axle - Page 2 - JeepForum.com
post #16 of 19 Old 03-31-2010, 03:41 PM
John92YJ
Originally Posted by sequel View Post
The front is a unit bearing...aka it has the hub and a sealed bearing all as one unit. Pretty common in today's cars.
Thanks dose someone make one that takes a pressed bearing?
John92YJ is offline
post #17 of 19 Old 03-31-2010, 06:01 PM
joshbaker92yj
Yes its called hub conversion and it pretty much changes the unit bearing set up to a d44 like setup. but you dont get much streanth from it but you do get lock out hubs they are about $800. Mile marker and warn make them.
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #18 of 19 Old 03-31-2010, 06:23 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Supposedly '87-'89 YJs came from the factory with a rebuildable hub, and unit bearings began being installed in '90. Chances are by now most early YJ hubs have been replaced with a unit hub/bearing at some point over the years... I know mine have.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #19 of 19 Old 04-01-2010, 09:53 AM
John92YJ
man i hope not to many people put 800$ parts in a d30 lol. Thanks for the reply's
John92YJ is offline
front axle question Mudr83 TJ Wrangler Technical Forum 12 11-23-2008 06:32 AM
Front Axle question D30 HP 97MilitaryTJ TJ Wrangler Technical Forum 4 02-21-2008 03:46 PM
Front axle question jskonz TJ Wrangler Technical Forum 2 11-23-2007 08:05 PM
front axle question RnEmOvr YJ Wrangler Technical Forum 4 02-27-2006 04:33 AM
Front axle question Fastbeeatch YJ Wrangler Technical Forum 3 04-27-2004 04:30 AM
