Question regarding front axle - JeepForum.com
post #1 of 19 Old 02-15-2010, 03:09 PM Thread Starter
hdfxrs91
1987 YJ Wrangler
Question regarding front axle -- Fixed!
Hello all,
I replaced the front pads and rotors on my 87 the other day. Putting the wheels back on, I noticed that on the right (passenger) side, the axle portion (not the knuckle) of the assembly had a lot of play, whereas the driver's side does not. When I say play, I mean I can move the rotor assembly back and forth, and see the U-joint moving with it. My thoughts are that this is the "short axle" side and it's normal, but I wanted to be sure by asking the experts here. My experience is limited when it comes to 4-wheel drive drivetrains.
Thanks
Edit: I shouldn't say "back and forth". I should have said "up and down" and "left and right".
hdfxrs91 is offline
post #2 of 19 Old 02-15-2010, 03:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like a bad unit (wheel) bearing to me.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 19 Old 02-15-2010, 03:56 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Unit bearing is shot
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 19 Old 02-15-2010, 03:58 PM
Rocky_Cosmark
Yea, that is the short side actually, but it sounds like a bearings bad like he said, does your wheel ever shake alittle while driving?
Rocky_Cosmark is offline
post #5 of 19 Old 02-15-2010, 04:18 PM Thread Starter
hdfxrs91
1987 YJ Wrangler
No shaking, but now that I think about, I did hear a knock on that side now and then. Thanks for all the replies.
hdfxrs91 is offline
post #6 of 19 Old 02-15-2010, 04:30 PM
Gobi_Gred
1987 YJ Wrangler
Not a diffucult repair. There are 3 12-point bolts on the back side of the knuckle. Then there is a BIG nut that holds the axle onto it.
Most likely it is all rusted together. What I have done is take the axle out with the bearing and work on it on the bench.
If you can find a good one at the junkyard(impossible around here) you can just slide the whole new one in and only deal with those 3 bolts
Gobi_Gred is offline
post #7 of 19 Old 02-15-2010, 09:41 PM Thread Starter
hdfxrs91
1987 YJ Wrangler
I know I'm being lazy by not going to the garage to get the Haynes manual, but are the bearings pressed in like a front-wheel drive unit or are they tapered bearings like a normal hub?
hdfxrs91 is offline
post #8 of 19 Old 02-15-2010, 09:46 PM
burnout189
they are a unit bearing meaning that you unbolt the whole assy with 3 bolts, toss it, and bolt on the eniter new hub, wheel studs and all.
BARNHART'S AUTO REPAIR
burnout189 is offline
post #9 of 19 Old 02-15-2010, 10:24 PM Thread Starter
hdfxrs91
1987 YJ Wrangler
Oh, I see. Thanks. I thought it might have been a repairable item. Silly me, what was I thinking? It is a Jeep after all.
$84 at NAPA
hdfxrs91 is offline
post #10 of 19 Old 02-15-2010, 10:52 PM
sequel
When you go to remove the unit bearing from the knuckle, usually they are stuck on there pretty good. Here is the easy and cheap way to get them off:
http://www.stu-offroad.com/axle/unit...tbearing-1.htm
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #11 of 19 Old 02-25-2010, 10:03 AM Thread Starter
hdfxrs91
1987 YJ Wrangler
So I bought a new unit bearing (Advance Auto, $70), and nearly split a kidney trying to get that nut off. Haynes manual says 175 ft-lbs. Luckily I have friend that works at a garage, and he'll get that off for me. What do you guys do to get it back on, though? Put the wheel on the ground and torque it from there? Or jam prybar in the studs and let it hit against the ground?
hdfxrs91 is offline
post #12 of 19 Old 02-25-2010, 12:07 PM
disarm6565
I put a wrench inbetween the knuckle and the axle shaft and crank it back on with a breaker bar.
1993 4.0 AX-15
disarm6565 is offline
post #13 of 19 Old 02-28-2010, 10:23 PM Thread Starter
hdfxrs91
1987 YJ Wrangler
Got it done today. Really is not that bad of a job. Of course the unit refused to budge, but a gear puller and a few light taps with a 3lb sledge work wonders. It seemed to be stuck more on the knuckle than on the splined shaft. Well, onto the next job... replacing the slave cylinder.
hdfxrs91 is offline
post #14 of 19 Old 03-29-2010, 05:44 PM
John92YJ
I have a bearing going out so I was just going to replace the bearing but you guys are saying I haft to replace the hole hub is that right?
John92YJ is offline
post #15 of 19 Old 03-29-2010, 05:53 PM
sequel
The front is a unit bearing...aka it has the hub and a sealed bearing all as one unit. Pretty common in today's cars.
sequel is offline
front axle question Mudr83 TJ Wrangler Technical Forum 12 11-23-2008 06:32 AM
Front Axle question D30 HP 97MilitaryTJ TJ Wrangler Technical Forum 4 02-21-2008 03:46 PM
Front axle question jskonz TJ Wrangler Technical Forum 2 11-23-2007 08:05 PM
front axle question RnEmOvr YJ Wrangler Technical Forum 4 02-27-2006 04:33 AM
Front axle question Fastbeeatch YJ Wrangler Technical Forum 3 04-27-2004 04:30 AM
