question regarding factory replacement "heavy duty springs" - JeepForum.com
post #1 of 8 Old 07-16-2013, 12:10 AM Thread Starter
Xzero117
I want to replace the old sagging springs on my jeep, I currently have 1 inch lift boomerang shackles on it giving me 1 inch of lift and a 1 inch body lift
my question is, what is the deal with the "heavy duty" standard replacement springs, as opposed to the "standard" duty replacement springs ?
is there a difference in height between the two ? a difference in ride quality ?
I recently did a 350 sbc swap so the front end is about 50lbs heavier than stock up front, thus why i'm considering the "heavy duty" spring set
Xzero117 is offline
post #2 of 8 Old 07-16-2013, 12:13 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
I believe the "heavy duty" would be for the hard top. Mine came with a soft top and the tires scrub the fenders on rolling bumps with the hard top on.
Michaelgoesrawr is offline
post #3 of 8 Old 07-16-2013, 12:15 AM Thread Starter
Xzero117
In case someone suggests lift springs, I'd rather keep the jeep with just a 1 inch suspension lift as not to effect with it's on-road manners and stability too much, the toughest obstacle i'll see is a snowday or two in a year.
Xzero117 is offline
post #4 of 8 Old 07-16-2013, 12:17 AM Thread Starter
Xzero117
i see, mine came standard with a hardtop, so i guess i should just go straight with the heavy duty set
Xzero117 is offline
post #5 of 8 Old 07-16-2013, 12:17 AM
Michaelgoesrawr
I understand. Personally I'd weigh the 1"-1.5" lift spring options to help with the additional weight of the motor.
And in your case I'd go with the heavy duty.
Edit: Yeah, what you said.
post #6 of 8 Old 07-16-2013, 12:24 AM
kgb_m3
Heavy vs regular is simply added spring rate and sometimes added leaf to a pack. 4 pack spring with lower spring rate is regular duty. 5 pack or more with higher spring rate is heavy duty. Accounts for hard top, heavy bumpers, winch, etc..
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #7 of 8 Old 07-16-2013, 09:26 AM
bmedeiros678
Heavy was for hardtop. Just replaced my wife's last year with stock replacement heavy duty from crown. Was under 400.00 for all four if I remember correctly. I live in MA so am able to deal with them directly.
'93 YJ Renegade
'91 XJ Briarwood
'85 CJ7 Laredo
bmedeiros678 is offline
post #8 of 8 Old 07-16-2013, 10:29 AM
Rproject
1987 YJ Wrangler
I looked at both Crown springs and lift springs when I upgraded last year. I ultimately decided to go with lift springs, but that was my decision. If I had not gone with lift springs, heavy duty Crowns would have been my second choice. The Heavy Duty springs are supposed to be for 6-cyl motors and vehicles with hard tops. The Standard Duty are for 4-cyl soft top models. That information came from Morris 4x4, whom I trust when it comes to buying schtuff of the Jeep.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
