Question for MC front fender owners - JeepForum.com
post #1 of 8 Old 09-01-2013, 06:16 PM Thread Starter
crackedcornish
Hey guys, just installed my MetalCloak overline front fenders today, and the bottom edge of my hood rubs on the inside of the top rail of the fender frame when I close it...anybody else ever have this happen to them?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is online now
post #2 of 8 Old 09-02-2013, 03:47 AM
timatoe
timatoe's Avatar
I could've sworn this was addressed in the install instructions but I just read through them three times online and there's nothing. Maybe I got an extra page with mine, or maybe Matson told me when I picked them up that it could happen. Either way the answer is yes it can and did happen to me with mine. I ran a ratchet strap around the entire hood and sucked it in until it bent in enough at the bottom lip to clear. I only had to do it a couple times to get it to fit. I notice the slight bend with the hood up, because I know it's there, but I doubt anyone else would ever see it.
I was trying to find a pic, but then photobucket refused to cooperate and froze up so this is the best I could find.....
timatoe is offline
post #3 of 8 Old 09-02-2013, 08:46 AM Thread Starter
crackedcornish
thanks for the info timatoe, I knew with all of the members here who have these fenders, someone would have run into this and have the right solution.
when my father and I were discussing how to fix this problem I thought about using a ratcheting strap to suck the bottom edges in a bit, but I wanted to wait and see if there was some adjustment step I had missed before I did something unneeded to my hood.
I sent an e-mail to Will asking him about it (and about the powdercoating on my rear flares being all chipped up, even though all of the shipping packaging and padding was intact) yesterday afternoon... but all I received was an automated reply about them being away because of the holiday weekend.
...oh timatoe, did you just cut the front mounting tab off of your battery tray like the install direction say to do for the '87-'90 YJ's? If you did how is it working out?
I didn't like the idea of all the weight of my battery levering off of the firewall with no support at the inner fender, so I cut and modified the front mount to work with the MC inner fender
like this
post #4 of 8 Old 09-02-2013, 05:20 PM
timatoe
timatoe's Avatar
Yeah, they've been at the Rubicon all weekend for the Cantina on the Con.
On the battery tray, I actually ditched the stock tray and used a Optima tray from Ruff Stuff. I re-used the stock holes in the firewall at top and bottom with no tie in to the inner fenders......
timatoe is offline
post #5 of 8 Old 09-02-2013, 06:33 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
My hood rubbed as well. It took me a while to figure out what the wretched squeeking was. I tried to massage the hood with a hammer (gently) and pliers on the inside lip, but nothing quite eliminated it until I removed the hood to do my hood louver. After I reinstalled it there was no more noise, and it doesn't look like I moved it at all.
Randonexplosion is online now
post #6 of 8 Old 09-03-2013, 01:17 AM
Sparrows
Mine rubbed a tad at first as well. There is a LOT of ways to adjust your hood and grill though. Play with the hood hinges a bit. Loosen the grill body mount, the two braces, and the MC grill mounts. Between all that I was able to get mine set up sweet with zero rubbing issues.
Cheers
June '13 YJOTM
Sparrows is offline
post #7 of 8 Old 09-03-2013, 08:33 AM Thread Starter
crackedcornish
Cheers
oh believe me, I tried all of that, I have my hood perfectly lined up with the cowl and the fenders are perfectly lined up with the tub and grill, I have everything square and straight...but the hood still rubs on the rear of the top rail of the fenders on both sides. I would either have the rear of the fenders sticking out past the tub about a 1/2" at the rear, or have the front about an inch away from the grill to have enough clearance to keep from rubbing. I think if I can squeeze the hood in about a 1/4" on each side it will be just fine
If MC would just make the gap between the hood and fender the same at the rear of the arch as they have at the front, all of this rubbing stuff could have been avoided. IMHO the fenders would look better too
you can tell the MC guys don't wheel much in the woods, I can see leaves and twigs getting stuck in that tapered section between the hood side and fender rail
post #8 of 8 Old 09-03-2013, 08:41 AM
Ripper3494
Sent from AutoGuide.com App
Ive actually never had that problem. Though they work great for bouncing off trees.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
