Question for Max...or anyone else that may be able to answer - JeepForum.com
post #1 of 11 Old 05-04-2011, 04:42 PM Thread Starter
kelti819
On a 92 d30 axle are the axleshafts on the left and right the same? if i have a spare shaft from the left side can i put it on the right side. it has the hole that the nipple on the intermediate shaft slides into but are there any other differences?
kelti819 is offline
post #2 of 11 Old 05-04-2011, 04:51 PM
TheNewbie
I wouldn't think that the same shaft would work for both sides. The diff is not in the center.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 11 Old 05-04-2011, 04:59 PM
baritone_mike
I think the right side is a two piece shaft that slides over and connects when you put it in 4WD. The left is just a one piece.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #4 of 11 Old 05-04-2011, 05:03 PM
cubewhiz
That is correct. The passenger side, because of the vacuum system, is two pieces. The pumpkin is offset towards the drivers side, so even if you wanted to convert to a one-piece shaft, you'd still need a longer shaft.
In short, it won't work.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #5 of 11 Old 05-04-2011, 05:15 PM Thread Starter
kelti819
ummm....ok maybe i did not word this right.
the drivers side has a stub shaft that goes through the hub assembly and connects to an axle shaft that goes to the diff. t
the passanger side has a stub shaft that goes through the hub assembly with an axle shaft that goes to the vaccuum disco, and then connects to the intermediate shaft.
the collar attaches the passanger side axle shaft and the intermediate shaft....
i want to know if the axle shafts that connect to the hub assemblys are the same for both sides....i have a spare that i know for a fact came off of the drivers side, but it too has the hole on the spline end that would slide into the nipple on the end of the intermediate shaft at the vaccuum disco.
kelti819 is offline
post #6 of 11 Old 05-04-2011, 05:23 PM Thread Starter
kelti819
are (1) and (3) the same in this pic is what i am trying to find out
kelti819 is offline
post #7 of 11 Old 05-04-2011, 05:23 PM
kloppk
Originally Posted by kelti819 View Post
i want to know if the axle shafts that connect to the hub assemblys are the same for both sides.....
No they are not the same.
In your D30 the only axle shaft parts that are the same are the stub shafts.
The other 3 axle shaft parts are all different.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #8 of 11 Old 05-04-2011, 05:26 PM Thread Starter
kelti819
sorry this one should be bigger
kelti819 is offline
post #9 of 11 Old 05-04-2011, 05:27 PM Thread Starter
kelti819
sorry apparently i cant make the image bigger...
looking at them and looking in the quadratech book they look the same, can you tell me what the differences are?
kelti819 is offline
post #10 of 11 Old 05-04-2011, 05:31 PM
kloppk
The passengers side one looks like this.
Drivers will look like this.
Note the difference in the diameter of the ends of the two shafts.
The drivers side is normal 27 splines where it engages with the differential.
The Passengers side if MUCH larger. This large section is where the CAD collar engages and joints the intermediate with it.
Baystate Jeepers
Deep Woods Extreme
kloppk is offline
post #11 of 11 Old 05-04-2011, 05:32 PM Thread Starter
kelti819
i see now it is bigger on the spline end, sorry jeep is not here for me to pull the vac disco cover off to realize that. thanks for the help. guess i have a spare that cant be used by me now.
kelti819 is offline
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
need and answer to and old question. (gas gauage) jerico TJ Wrangler Technical Forum 6 09-25-2006 08:16 PM
A stupid question I should know the answer to... Jeep05 TJ Wrangler Technical Forum 2 01-05-2006 12:19 PM
answer my question...please Dizzy92 YJ Wrangler Technical Forum 7 09-07-2004 09:43 AM
Stupid question but please answer AJKoontz TJ Wrangler Technical Forum 2 01-22-2004 11:01 PM
