Question on Lockers for Wrangler - JeepForum.com
post #1 of 7 Old 10-17-2007, 03:00 PM Thread Starter
aelar1
Hello everyone. I am in the market for a 1995 Wrangler. Its from a private seller and I test drove it and the rear end clicks and kind of jolts when making sharp turns. There is lockers in the front and rear supposedly. Is this clicking and jolting a result of the lockers or do you think something is wrong. Ths allignment is off. thanks for any help
aelar1 is offline
post #2 of 7 Old 10-17-2007, 03:11 PM
drummerman0123
its probably got a lunch box type locker in it like a lock right. those lockers tend to do the jolting and it clicks because that is how it works. When ever making sharp turns you can keep in from jolting by taking it out of gear.
93 YJ
drummerman0123 is offline
post #3 of 7 Old 10-17-2007, 03:22 PM
coachchuck
You discribed the actions of a lunch box locker.
Chuck
Sold : 93 YJ, 33s, 4.1, HO 4.0, AX15, d300 flipped
Building 90YJ. 37s, 5.38, 350, 4L60, np241, d44-ARB, D60-spool
coachchuck is offline
post #4 of 7 Old 10-17-2007, 05:05 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
like all the others, it is a lunchbox locker, when you make the sharp turn, obviously the outside wheel spins more then the inside wheel, making the locker think the outside tire has no traction, and engages to give more power to the inside wheel thus speeding up its rotational speed, this is what gives the jolt you are describing, no biggie, you'll get use to it. i have a detroit locker in mine and it does it every once in a while.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #5 of 7 Old 10-17-2007, 05:52 PM
RockWoRM
RockWoRM's Avatar
Originally Posted by mean90yj
.I have a detroit locker in mine and it does it every once in a while.
so does mine, so it "may" not be a lunchbox.
the owner should know what's in there, unless he bought it that way, too. U can always pull a diff. cover if ya really need to know... then the owner can throw in some new gear oil!!!
edit note: give it a good going over when U drive it... if it constantly clicks and bangs, that could be a sign of wear... the ratcheting teeth getting worn... depending on what it is of course. Once in a while is OK, but all the time and I'd be concerned.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #6 of 7 Old 10-17-2007, 06:46 PM
pasinbuy
Sound Ok to me too.
pasinbuy is offline
post #7 of 7 Old 10-19-2007, 12:19 PM
SWAMPED
Junior Member
ditto.....i got a rear locker and thats exactly what it does
SWAMPED is offline
Lockers Question Beltfed09 Wrangler General Discussion 4 08-05-2009 06:51 AM
Installing rear lockers on a 2007 4d wrangler X LLOOWWKKEEYY Wrangler General Discussion 1 02-26-2009 10:00 AM
Lockers 89 Jeep Wrangler 89jeep2 YJ Wrangler Technical Forum 13 10-27-2007 06:39 AM
Installing lockers in 94 Wrangler Atesjay YJ Wrangler Technical Forum 20 04-28-2007 06:53 AM
question on arb lockers wranglerx03 TJ Wrangler Technical Forum 1 04-05-2003 08:35 PM
