A question before I start building. - JeepForum.com
post #1 of 1 Old 02-21-2012, 06:55 PM Thread Starter
Ok I have collected a ton of parts from shackles to gears to lift my YJ and do it right. Unfortunately with a wedding coming in 2 months I couldn't quite spend all the money I wanted all at once.
here is what I have:
4" Springs of unknown brand because they were slightly used and passed hands quite a few times
Shocks - just front for now
Drop pitman arm
1/2" boomerang shackles
8.8 Explorer axle
4.88 gears for dana30 and 8.8 with master rebuild kits
8.8 install kit - u bolts, plates, shock tabs, and spring perches.
4 33" mickey thompson mtzs mounted on 15x8 d-windows
All new steering and suspension items - bushings, TRE's, blah, blah, blah.
What I am wondering is when I weld up the 8.8 will it be a big poblem to go ahead and set the pinion angle for a SYE? I will be getting one very soon, just not right at the moment. Am I correct in my understanding that a double cardan drive shaft requires a different pinion angle than a regular stock driveshaft? I understand I will probably have vibes but the u-joints in the driveshaft have less than 500 miles on them so maybe they will last a little longer.
I know everyone is going to say wait for the SYE, but that is not an option because I will be starting a job next week that will leave me virtually no time to get all this big stuff done.
Also, another question. Since I will be welding on new shock tabs, if I weld them up high enough to be out of the way, should I order less than 4" lift shocks since the stock position is a couple inches below the axle tube?
Ryno_XJ is offline
91 4.0 wont start. frustration building kodiakkris400 YJ Wrangler Technical Forum 16 06-08-2011 05:05 AM
Want to start building, few questions. redrelyt12 TJ Wrangler Technical Forum 0 03-02-2011 04:10 PM
Building up a stock TJ - where to start? ChrisTJCO TJ Wrangler Technical Forum 16 03-12-2010 08:43 PM
Building my Jeep - where do I start? imbezol TJ Wrangler Technical Forum 3 09-05-2006 04:37 AM
start building Joeys97TJ TJ Wrangler Technical Forum 2 05-19-2005 08:07 AM
