question about stock YJ suspension - JeepForum.com
post #1 of 2 Old 10-05-2001, 08:41 PM Thread Starter
evilpsych
evilpsych's Avatar
OK.. went to look at a '93 this afternoon..
felt like the rear-end was squatting a lot and maybe twisting/sliding laterally in turns.. is this normal? or is there something wrong like sagging springs or worn bushings? also.. the steering jumped around from right to left occasionally, not much distance moved, but enough to worry me how it would handle at freeway speeds.. it a worn tie-rod or what..
heh.. i'm a newbie so cut me some slack.. heheheheh
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 2 Old 10-06-2001, 12:35 AM
Nightclaw
Actually, that sounds a lot like how my Jeep drives having removed the axle track bars. Peek underneath and look for a thick bar connected from the differential housing to the frame. If there is no bar there, that would explain the driving characteristics you describe.
If the track bar IS in place though (there's also one attached to the front axle), it could be something worn out, most likely spring bushings. Besides this, it'd be hard to say without looking at it first-hand.
Nightclaw is offline
stock suspension question zoid TJ Wrangler Technical Forum 2 04-02-2009 07:59 PM
08rubicon all stock... widest tires with stock suspension greenbudz JK Wrangler Technical Forum 6 12-11-2008 12:11 PM
TJ vs CJ & YJ Stock Suspension Question leeave96 TJ Wrangler Technical Forum 2 12-23-2007 09:28 PM
How Big Can I go with stock Suspension on my JKJ MoparMadness JK Wrangler Technical Forum 18 04-10-2007 09:10 PM
stock Rubicon suspension on a stock Unlimited? IneedaJEEP TJ Wrangler Technical Forum 3 03-21-2005 02:04 PM
