Question about shackle bushings - JeepForum.com
post #1 of 10 Old 08-23-2011, 09:28 AM Thread Starter
NewYJOwner
Tried searching but got more confused than ever, I put boomerang shackles on my YJ but the front bushings are worn out and need replaced. I ordered 2 leaf spring shackle bushing kits (consist of 4 bushinga and 2 sleeves).
Are the frame to shackle bushings and spring to shackle bushings the same size?
Basically, Are these the same size bushings?
NewYJOwner is offline
post #2 of 10 Old 08-23-2011, 10:35 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
No, the frame bushings are different than the spring bushings.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #3 of 10 Old 08-23-2011, 10:59 AM Thread Starter
NewYJOwner
HHMMM I get conflicting answers on this...some say yes some say no...
post #4 of 10 Old 08-23-2011, 11:08 AM
jbolty
jbolty's Avatar
The bushing on either end of the shackle are the same size. The bushing on the other end of the spring is different in most cases. The shackle end has 1/2 bolts and the stationary end has 9/16 bolts.
Having the proper bushings matched with the proper length inner sleeve is the most important part of this whole project. There are all sorts of thread about leaving the shackle bolts loose so it will flex but all that is because of the wrong inner tube length.
jbolty is offline
post #5 of 10 Old 08-23-2011, 11:39 AM Thread Starter
NewYJOwner
So if I order 2 of these...http://www.oreillyauto.com/site/c/de...3964&ppt=C0361
It will replace the 4 bushings and 2 sleeves in the front of springs and the 4 bushings and 2 sleeves in the frame mount where the shackle bolt up right?
post #6 of 10 Old 08-23-2011, 11:49 AM
jbolty
jbolty's Avatar
Do yourself a favor and get a complete kit with greaseable bolts from MORE. I went the same route with shackles from here and bushings from there and bolts from another place and no matter what it just never worked right. After replacing everything the amount of flex improved instantly and the ride got a little smoother and more quiet.
Check for sales, discounts and coupons.
jbolty is offline
post #7 of 10 Old 08-23-2011, 03:10 PM
hrt4me
thanks for the tips!
hrt4me is offline
post #8 of 10 Old 08-23-2011, 08:43 PM
yellow2kgt
I agree, Go with m.o.r.e. Just call them up and tell the the brand of springs you are running. No second guessing or trying to find the right bolts. It is spendy but you will be rewarded with a bolt on deal.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #9 of 10 Old 08-24-2011, 04:39 PM Thread Starter
NewYJOwner
OK for future refrence, YES, the frame to shackle mount bushings are the same as the front leaf spring to shackle bushing. Just installed my energy suspension poly leaf spring shackle bushings autozone part #2.212OC $30 for 2 sets compared to $54+ from my local auto parts.
post #10 of 10 Old 08-24-2011, 07:11 PM
pasinbuy
Good question and the answer is that it depends on what brand springs that you have.
On my Yj the main and the shackle bushings are the same size.
pasinbuy is offline
Shackle Bushings ptwhaler YJ Wrangler Technical Forum 8 05-24-2011 06:20 AM
where to buy shackle bushings offrdjeepfreak8 YJ Wrangler Technical Forum 1 07-10-2009 07:13 AM
shackle bushings? 1993sahara YJ Wrangler Technical Forum 3 01-14-2009 08:05 PM
Shackle Bushings Johnny World YJ Wrangler Technical Forum 5 04-11-2006 07:08 PM
Shackle Bushings Question JMark YJ Wrangler Technical Forum 19 04-27-2004 12:21 PM
