Question about pulley - JeepForum.com
post #1 of 4 Old 02-24-2010, 06:44 AM Thread Starter
spawnofsatan
Guys the pulley in front of the power steering can this be replace? Mine is making noise and it's very annoying. Also since I remove my AC and does the Compressor need any lubing?
spawnofsatan is offline
post #2 of 4 Old 02-24-2010, 06:47 AM
73Dart
Yes the power steering pully can be replaced bu the case cannot stand the strain. Therefore it has to be taken apart to have the pulley pressed on.
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar.
73Dart is offline
post #3 of 4 Old 02-24-2010, 08:03 AM
EABiker
What kind of noise is it making? Any noise is most likely the pump itself. New pumps do not come with a pulley; you need to rent or buy a power steering pulley removal tool to DIY.
EABiker is offline
post #4 of 4 Old 02-24-2010, 08:20 AM Thread Starter
spawnofsatan
the the noise only happens at around 800 rpm above that its fine i'll check the belt this weekend.
Belt Pulley Bering Question. fireshadow YJ Wrangler Technical Forum 2 05-29-2009 01:57 PM
Odd engine pulley setup? Question.. Duncan71 YJ Wrangler Technical Forum 7 12-14-2008 04:49 PM
4 banger pulley question Sh4dowRac3r TJ Wrangler Technical Forum 8 05-12-2007 12:05 PM
Pulley question, could use some help jeepr72 TJ Wrangler Technical Forum 13 09-17-2006 11:51 AM
Help...idler pulley, P/S pulley, serpentine belt? BaltimoreJeep YJ Wrangler Technical Forum 23 02-17-2005 02:33 PM
