question about leak at rear axle - JeepForum.com
post #1 of 10 Old 01-13-2014, 05:04 PM Thread Starter
tkwok
Hello
I noticed some oil accumulation on the rear axle next to the differential of my 95 YJ today. Is there a seal here that I can replace? I've never did any work on an axle before besides changing out the differential fluid so I'm a little lost. I've wiped down some of the oily residue prior to taking this photo but most of the accumulation was located inside the marked circle.
any help or tips would be appreciated.
thanks
tkwok is offline
post #2 of 10 Old 01-13-2014, 05:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How much are we talking? Those tubes are pressed inside the cast pumpkin and there is only pressure to really seal them inside. I suppose if you didn't already twist a tube or bend one you could try a little silicone on the outside to stop the leak. The axle isn't worth putting large amounts of money into and can be found in fairly decent shape on Craigslist all day long
Where are you exactly?
Luck Favours The Prepared
Anticanman is offline
post #3 of 10 Old 01-13-2014, 05:22 PM Thread Starter
tkwok
I didn't do any damage to the tube itself. The amount of oil leaking is not excessive. It is not leaking onto my driveway. But there was enough accumulation in that area that I was able to take notice of the leak. Are you saying I can just put a bead of black RTV around the tube at the differential joint as a bandage?
I;m in Los Angeles.
tkwok is offline
post #4 of 10 Old 01-13-2014, 05:31 PM
jbolty
jbolty's Avatar
Have you identified the source? Could be the cover, tube, pinion seal or the vent.
jbolty is offline
post #5 of 10 Old 01-13-2014, 06:20 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Vent is on the other side of the jeep so I hope it isn't that.
post #6 of 10 Old 01-13-2014, 07:53 PM Thread Starter
tkwok
It looks like the oil was coming out of where the tube meets the pumpkin.
Where is the vent exactly again?
tkwok is offline
post #7 of 10 Old 01-13-2014, 08:02 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
There should be a hydraulic tie-in block attached to the driver side of the tube near the top. The softline from the frame comes down to it and splits the hydraulic pressure side to side. The breather exits this same block by way of a black rubber tube that tucks up into the rear driver side tub corner.
This is not a D35, but the breather configuration is the same. There's a block on top of the axle tube a few inches from where you see the shock where the rubber hose attaches & goes up into lala land. That's the breather tube.
Joe Dillard is offline
post #8 of 10 Old 01-14-2014, 07:19 AM
1320yj
The only way to effectively seal the axle tubes is to weld them. leaking means they are getting loose and only welding will fix that.
Welding axle tubes is common practice in race cars ask someone in your local speed shop for a place that does this.
Silicone will not hold.
1320yj is offline
post #9 of 10 Old 01-14-2014, 12:31 PM
tom_sprecher
If it is not leaking enough to make a spot on your driveway why bother trying to fix it?
Tom
tom_sprecher is online now
post #10 of 10 Old 01-14-2014, 03:33 PM
Jeepsr4me
I never saw a leak there with out some damage to the housing. Oil can fly off the engine area and vortex action be picked up elsewhere. The tubes are pressed in so tight there really is no way for the oil to get pass... If its coming out, look for a crack.
Get some brake cleaner and go to town cleaning it. After you do that take a rag and tie around tube. If its coming from else where the oil will be on the outside, if from the diff it will be on the inside. Clean it good as oil will try to migrate in the joint of the pressed tube and housing.
Jeepsr4me is offline
axle , dana 35
