Question about Internal/External Slave on AX5 - JeepForum.com
post #1 of 5 Old 03-11-2010, 03:34 PM Thread Starter
misbehavin
My Transmission blew up on me and i got a hold of a another AX5 out of a 95 yj and was wondering if if it has an internal or external slave, im a little unsure on when the switch was made to the external style and i dont know what to look for.
Im pretty sure that they are the same thing but want to make sure before i drop my transmission out and try and put everything back together again.
misbehavin is offline
post #2 of 5 Old 03-11-2010, 05:27 PM
95jy
95 should be external, that one looks like a internal though
95jy is offline
post #3 of 5 Old 03-11-2010, 06:07 PM Thread Starter
misbehavin
hmm, alright, here are some more pictures of the trans if it helps at all.
post #4 of 5 Old 03-11-2010, 06:27 PM
Uberjeep
[QUOTE=misbehavin;9065388]My Transmission blew up on me and i got a hold of a another AX5 out of a 95 yj and was wondering if if it has an internal or external slave, im a little unsure on when the switch was made to the external style and i dont know what to look for.
QUOTE]
That one is definitely internal in the pics. The two brake lines coming into the bellhousing are a giveaway. The one line runs to the clutch master cylinder, the other pokes out to a bleeder valve. If you have the option of finding an external slave bell housing with the fork & all, I would grab it and convert. When I had to bleed my internal slave, it was a MAJOR PITA, swore I will never do it again.
The ones with the external will have an obvious cylinder on the OUTSIDE of the bell housing where one of those two lines comes out. You will see a small plastic cover plate with two bolts/screws holding it over the opening that the line comes out of. This pic shows an external slave in place.
Originally Posted by 2003Rubi View Post
Make sure you get a sticker that says "Jeep" in Japanese lettering, that mod is good for about 20-25 hp right there.
My Jeep has only ever killed three things. A deer, a dog, and my wallet.
*retired* Low Output Jeep Club # 135
Uberjeep is offline
post #5 of 5 Old 03-11-2010, 06:49 PM
95jy
thats what i thought the pic of the back confirmed it
95jy is offline
Internal or external slave? XsaltlifeX YJ Wrangler Technical Forum 2 09-23-2009 07:15 PM
Internal slave to external slave conversion on puegout trans. zippome YJ Wrangler Technical Forum 11 04-20-2009 10:26 AM
Internal or External Slave Cyl 73Dart YJ Wrangler Technical Forum 6 04-15-2009 09:57 PM
Internal Slave to External teaser73 YJ Wrangler Technical Forum 6 01-26-2009 11:36 AM
Internal or external slave? Sawbladz TJ Wrangler Technical Forum 3 05-14-2007 11:15 AM
