question about (aussie) locker - JeepForum.com
post #1 of 7 Old 08-08-2005, 02:00 PM Thread Starter
Dennisr
Hello,
For a few months now I'm the owner of a wrangler '91. This car is for me to play with and I really like it..
Now I want to have more traction, especially at the front wheels and saw that the aussie lockers is a great way to do this. I prefer the ARB air lockers, but they cost approx. 1500 USD per axle over here.
The thing that I want to know is that when you have this type of locker in your front axle and you switch to 4wd it will do his work and give traction to both wheels. And if you switch to 2wd it will have no effect on the onroad behaviour because my wrangler will disconnect the right axle, wright?
Is this correct or do I see this wrong, because I also want to drive my car on road
Greetings,
Dennis from Belgium/Holland
Dennisr is offline
post #2 of 7 Old 08-08-2005, 02:03 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
You are correct. It could get a bit hairy diving in 4hi on an icy road with the aussi or any kind of locker in there. But for normal driving in 2wd you will be fine.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 7 Old 08-08-2005, 02:07 PM
speedracer2536
i think it will dissconect on a yj as long as you have the two poexce right shaft but i belive you will still hear it when you turn and it might steer funny making left turns but im not a 100 percent sure i have a locked front and you can tell on the road hope that answers your question
speedracer2536 is offline
post #4 of 7 Old 08-08-2005, 02:36 PM
fastone110
fastone110's Avatar
just make a hand switch for the front right so u can switch it when u want to turn... it will replace the vacuum line
'88 yj wrangler 2.5L /w 3.5 black diamond suspension lift, 2" body lift, 1 1/4" shackles, detroit gearless front locker, lockright in rear, posi-lok, traction bars off, no sway, 35x12.50x15 baja claws on homemade beadlocks, 4.10 gears protected by homemade diff covers, TFI, herculined, 8000lb winch, GenRight Bumbers, BrownDog 1''MML, JB SYE, flowmaster, custom YJ dash, kicker 4" front speakers, sony explode cd player, rocker panel guards, custom SS red brake lines.
fastone110 is offline
post #5 of 7 Old 08-08-2005, 03:47 PM Thread Starter
Dennisr
But why do I need to switch it manual? the vacuum line does the trick already, or am I missing something?
I thought that when I switch from 4wd hi to 2wd hi the gearbox changes and the driveshaft in the front axle disconnects at the same time, or am I wrong?
What I do notice is that when I switch to 2wd the 4wd light stays on for some minutes. He never did that before. Does someone know what can be the problem?
Dennisr is offline
post #6 of 7 Old 08-08-2005, 06:13 PM
fastone110
fastone110's Avatar
4x4 Posi-Lok replaces the vacuum actuator with a cable operated actuator that puts the driver in control of the engagement from inside the cab. After engaging the transfer case, a one inch pull of the 4x4 Posi-Lok cable connects the right front axle to the intermediate shaft using the shift collar and fork, and 4-wheel drive is engaged! Simply reverse the procedure to disengage 4-wheel drive. 4x4 Posi-Lok also works great with lockers! When the front axle is locked, you can disengage the passenger side in order to make turns without wheel hop
post #7 of 7 Old 08-08-2005, 06:27 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
You shoudn't notice a front locker in 2WD. As mentioned, if you put the Jeep in 4WD on snow/ice covered streets with an Aussie up front it could handle a little strange since the roads might be too slippery to make the locker unlock going around turns. This would be the situation where you might want to be able to manually unlock the right axleshaft to keep the 2 front wheels from fighting each other.
You are right that the axle shaft will automatically connect and disconnect when you switch between 2 and 4 wheel drive, but in a situation such as an icy road, you might want to be able to disconnect that one wheel while still leaving the Jeep in 4WD. This way the front left wheel will still get power to pull you through the snow, but you wont have the right one locked in to mess up the handling.
If the light stays on for a while after shifting into 4WD it could mean that the automatic vacuum disconnect on the front axle isn't disengaging right away for any number of reasons such as bad vacuum lines or the disconnect mechanism in the axle might be gummed up or it might be in need of new parts soon. Your Jeep will be in 2WD as soon as you move the lever, the light just means that the right front wheel just hasn't disconnected yet. Mine does this sometimes if i haven't used the 4WD in a while, but once I start using it again it turns on and off immediatly.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
aussie locker question plyguitar45 YJ Wrangler Technical Forum 14 05-13-2009 11:25 AM
Aussie Locker Question HoustonTJ TJ Wrangler Technical Forum 8 02-21-2009 06:14 PM
Aussie Locker question jmhat98 YJ Wrangler Technical Forum 4 04-28-2007 09:14 AM
Aussie Locker Question 2004Jeeptj111 TJ Wrangler Technical Forum 18 03-08-2007 04:30 PM
aussie locker question fish4life TJ Wrangler Technical Forum 15 07-27-2006 04:20 PM
