Question about 8.8 swap - JeepForum.com
post #1 of 7 Old 04-22-2010, 07:33 PM Thread Starter
chasmosis1
I have an 8.8 out of a 97 Explorer. I have removed all the mounts, re-welded the spring perch mounts at the correct spacing and angle, welded the axle tubes to the housing and redone all the brakes with new brakes and 2 pass. brake lines. I built my own shock mounts from 2X4 steel tubing. I have the yoke adapter from the Explorer and a 1310 to 1330 conversion joint.
My question is about the track bar. In every picture and article that I have been through I do not see the track bar mount being reinstalled on the axle. Is it common to remove this when doing a swap?
Thanks, Chas
chasmosis1 is offline
post #2 of 7 Old 04-22-2010, 07:35 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Forget the rear tracbar & never look back.
Joe Dillard is offline
post #3 of 7 Old 04-22-2010, 07:37 PM
Burns95
I just did this swap and didnt install the trac bar. 99% of YJ owners will say it isnt needed since it is a leaf spring suspension. CJ's didnt have them from the factory.
Burns95 is offline
post #4 of 7 Old 04-22-2010, 07:41 PM
joshbaker92yj
Just finished my 8.8 swap with the M.O.R.E. kit and they dont even put the trac bar mount in the conversion kit. Not that i cared or even thought about it cuz i lost my trac bars a long time ago. lol
92 yj, 36 sx swamper, locked d30 and locked 8.8.
on the road again.
joshbaker92yj is offline
post #5 of 7 Old 04-22-2010, 09:11 PM Thread Starter
chasmosis1
That's what I thought. I just wanted to confirm it. I have never seen a leaf sprung vehicle with a trac bar before so I wanted to be sure. Thanks for all the input.
Chas
post #6 of 7 Old 04-22-2010, 10:33 PM
Alabamaranger
Ditto, never used the track bar.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #7 of 7 Old 04-23-2010, 08:07 AM Thread Starter
chasmosis1
Thanks alot for the info. It will not be going back on the 8.8.
Chas
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
4.0L swap into a 2.4L TJ question monkeygruven TJ Wrangler Technical Forum 3 03-01-2010 06:39 AM
tb swap question asbury YJ Wrangler Technical Forum 1 05-02-2009 11:38 PM
4.0 swap question lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 1 06-21-2002 09:29 AM
