Question on 8.8 I found - JeepForum.com
post #1 of 19 Old 01-22-2013, 05:44 PM Thread Starter
epettit
I found a 8.8 out of a 96 ford explorer and according to the tag on the rear end it is not a limited slip. It had a 4 10 on the tag but not "L" in between the two numbers. The question is will it really matter limited slip vs non? I currently have a stock d35 in the rear.
I was going to pull it this week end if it did not matter...if so I will pass on it
All comment welcome
Ed Pettit
epettit is offline
post #2 of 19 Old 01-22-2013, 05:57 PM
mrdeath2000
non-lsd means you can toss a lunchbox locker in there and go, no gear resetting.
LSD means you cant lunchbox it, but you can rebuild the LSD with the carbon disc set which comes with an f150 spring ~$110.
All depends on your plans. Either is worlds better than the D35.
Do you plan on getting a fullcase locker or selectable like an ARB, Eaton Elocker, or TruTrac?
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #3 of 19 Old 01-22-2013, 05:59 PM
skyj
All comment welcome
limited slip isnt really a deal breaker most likely its worn out anyway. I specifically wanted an open carrier one so I could put a full case locker in. just my personal preference, . if its a good deal buy it.
build thread:
skyj is offline
post #4 of 19 Old 01-22-2013, 06:17 PM
mrdeath2000
if you plan on putting a full case locker in like a Detroit (trutrac or locker), ARB, Eaton, anything like that, it doesnt matter what you get because you're replacing the carrier in the 8.8.
If you plan on just using a lunchbox autolocker like the Spartan/Aussie/lockright, then you NEED an open carrier.
post #5 of 19 Old 01-22-2013, 06:59 PM
CaptLeeB
Richmond makes a lunchbox locker designed for the 8.8LSD it is just more expensive than a spartan or Aussie.
CaptLeeB is offline
post #6 of 19 Old 01-22-2013, 07:45 PM Thread Starter
epettit
They want 160.00 with brakes etc. It looks to be in pretty good shape...nice and dry other then a small damp spot around the drain plug. The rotors spin nice and smooth...
Ed Pettit
epettit is offline
post #7 of 19 Old 01-22-2013, 07:50 PM
CaptLeeB
I paid $175 last week caliper to caliper and pulled it myself. Sounds like a good deal to me.
CaptLeeB is offline
post #8 of 19 Old 01-22-2013, 07:54 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Check the VIN sticker on the Explorer's door (or jamb) for the axle code.
42 = 4.10 gears with open differential
D2 = 4.10 gears with limited slip
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 19 Old 01-22-2013, 08:22 PM
gunshw301
Presidents' Day is coming up. If I remember right pick and pull runs half off specials for Presidents' Day. I picked mine up at one of these specials, paid something like 60 to 70 bucks, but had to pull myself.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #10 of 19 Old 01-23-2013, 12:00 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Gonna go pick one up Thursday for $50 already pulled. Its got 3.73 but that doesn't matter because its going in a 4 cylinder Yj and he's going to regear it himself to 4.88 in anticipation of 33's.
Luck Favours The Prepared
Anticanman is offline
post #11 of 19 Old 01-23-2013, 10:46 AM
mrdeath2000
^Nice, didn't know that.
I'd snag it for $160.
post #12 of 19 Old 01-23-2013, 01:26 PM Thread Starter
epettit
I thought the door post said 44 but I will have to double check unless you can decode it... It was on a Ford Exlplorer XL
Ed Pettit
epettit is offline
post #13 of 19 Old 01-23-2013, 01:45 PM
SeanB95YJ
I believe 44 (and D4) is 3.73 gears.... best bet before you pull the axle, pull the cover off and look at the edge of the ring gear - usually the ratio is stamped on that as well... if not, then count the teeth.
Wouldn't be the first time I've heard of the axle being different than what the door tag states. double-check to be sure.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #14 of 19 Old 01-23-2013, 01:47 PM Thread Starter
epettit
My bad the axle code did say "42"
Ed Pettit
epettit is offline
post #15 of 19 Old 01-23-2013, 02:20 PM
CaptLeeB
CaptLeeB is offline
