-   -   Question on 8.8 I found (http://www.jeepforum.com/forum/f12/question-8-8-i-found-1467617/)
epettit 01-22-2013 05:44 PM
I found a 8.8 out of a 96 ford explorer and according to the tag on the rear end it is not a limited slip. It had a 4 10 on the tag but not "L" in between the two numbers. The question is will it really matter limited slip vs non? I currently have a stock d35 in the rear.
I was going to pull it this week end if it did not matter...if so I will pass on it
All comment welcome
mrdeath2000 01-22-2013 05:57 PM
non-lsd means you can toss a lunchbox locker in there and go, no gear resetting.
LSD means you cant lunchbox it, but you can rebuild the LSD with the carbon disc set which comes with an f150 spring ~$110.
All depends on your plans. Either is worlds better than the D35.
Do you plan on getting a fullcase locker or selectable like an ARB, Eaton Elocker, or TruTrac?
skyj 01-22-2013 05:59 PM
All comment welcome
limited slip isnt really a deal breaker most likely its worn out anyway. I specifically wanted an open carrier one so I could put a full case locker in. just my personal preference, . if its a good deal buy it.
mrdeath2000 01-22-2013 06:17 PM
if you plan on putting a full case locker in like a Detroit (trutrac or locker), ARB, Eaton, anything like that, it doesnt matter what you get because you're replacing the carrier in the 8.8.
If you plan on just using a lunchbox autolocker like the Spartan/Aussie/lockright, then you NEED an open carrier.
CaptLeeB 01-22-2013 06:59 PM
Richmond makes a lunchbox locker designed for the 8.8LSD it is just more expensive than a spartan or Aussie.
epettit 01-22-2013 07:45 PM
They want 160.00 with brakes etc. It looks to be in pretty good shape...nice and dry other then a small damp spot around the drain plug. The rotors spin nice and smooth...
CaptLeeB 01-22-2013 07:50 PM
I paid $175 last week caliper to caliper and pulled it myself. Sounds like a good deal to me.
Mean Max 01-22-2013 07:54 PM
Check the VIN sticker on the Explorer's door (or jamb) for the axle code.
42 = 4.10 gears with open differential
D2 = 4.10 gears with limited slip
Max
gunshw301 01-22-2013 08:22 PM
Presidents' Day is coming up. If I remember right pick and pull runs half off specials for Presidents' Day. I picked mine up at one of these specials, paid something like 60 to 70 bucks, but had to pull myself.
Anticanman 01-23-2013 12:00 AM
Gonna go pick one up Thursday for $50 already pulled. Its got 3.73 but that doesn't matter because its going in a 4 cylinder Yj and he's going to regear it himself to 4.88 in anticipation of 33's.
mrdeath2000 01-23-2013 10:46 AM
^Nice, didn't know that.
I'd snag it for $160.
epettit 01-23-2013 01:26 PM
I thought the door post said 44 but I will have to double check unless you can decode it... It was on a Ford Exlplorer XL
SeanB95YJ 01-23-2013 01:45 PM
I believe 44 (and D4) is 3.73 gears.... best bet before you pull the axle, pull the cover off and look at the edge of the ring gear - usually the ratio is stamped on that as well... if not, then count the teeth.
Wouldn't be the first time I've heard of the axle being different than what the door tag states. double-check to be sure.
epettit 01-23-2013 01:47 PM
My bad the axle code did say "42"
CaptLeeB 01-23-2013 02:20 PM
1 Attachment(s)
Attachment 549274
The time now is 04:01 AM.
