Question on 1993 Sahara Springs - JeepForum.com
post #1 of 8 Old 12-02-2007, 08:26 PM Thread Starter
Ksplayland
I just purchased a Western plow from a 1991 Wrangler and when I tried to install-it won't fit. The unimount brackets are hitting the leaf spring-Are the springs longer on the Sahara? Frame shorter? Any ideas?
Ksplayland is offline
post #2 of 8 Old 12-03-2007, 07:25 AM
BadAddetude
Are you sure the brackets are from a YJ? did you take it off another jeep? I'd look up the Unimount diagram now, but im about to go to class. Are they stock springs?
EDIT:
Parts list and install instructons- http://www.westernplows.com/pdf/63294_112398.pdf
Do all the parts look farmiliar?
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #3 of 8 Old 12-03-2007, 08:55 AM Thread Starter
Ksplayland
Thanks for your help. I have called in the experts and taking it to dealer to install.
post #4 of 8 Old 12-03-2007, 10:10 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
This should be fairly easy to install...........
Do you have the wrong plow or parts???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 8 Old 12-03-2007, 12:21 PM
1stjeepfinally
The diagram shown for the
Western Plow link is for a 97 and up.
1stjeepfinally is offline
post #6 of 8 Old 12-03-2007, 12:22 PM
rustywrangler
This could actually be his issue. Some fabrication is gonna be involved now.
post #7 of 8 Old 12-03-2007, 01:34 PM
BadAddetude
That is correct!
My fault, i was confused when i first looked it up. I thought i had the right one.
http://www.westernplows.com/pdf/13641_042693.pdf
This, i believe is the right one. it even includes the instruction.
It should bolt right up easy, no need for a dealer of fab work. Hope this helps.
post #8 of 8 Old 12-04-2007, 06:56 AM
chuckyj95
I have the same mount on my 95 and the jeep I took it off had stock shackles and it was snuge. I have lift shackles and had to cup a 1/2 inch of it to make it fit and will proble take a little more of it in the spring. I dont know if this is normal but I had the same proplem.
The western section at this foum was a great help
http://www.letstalksnow.com/forums/
Chuck
Chuck Longwell
Mohawk NY
Looking for my next jeep
2008 Triumph Speedmaster
chuckyj95 is offline
Made an intake for my 1993 Sahara 4.0 - here's what I did Tobey YJ Wrangler Technical Forum 4 03-29-2009 06:17 PM
1993 Sahara - 5 Speed Tranny Shifting Hard - Thoughts? Tobey YJ Wrangler Technical Forum 1 07-27-2008 08:56 PM
Need help ! 1993 Wrangler Sahara Clutch loggy YJ Wrangler Technical Forum 0 02-04-2008 10:09 AM
Just picked up a 1993 Sahara for $1500!! Bigbadwolf54 YJ Wrangler Technical Forum 22 05-28-2007 05:46 AM
1993 YJ Sahara Door Lock Issue loggy YJ Wrangler Technical Forum 4 04-11-2007 08:52 PM
