quaker state Defy - JeepForum.com
post #1 of 13 Old 02-23-2013, 05:13 PM Thread Starter
chuck172
quaker state Defy
Has anyone tried Quaker State Defy synthetic blend motor oil?
Seems right for our jeeps!
chuck172 is offline
post #2 of 13 Old 02-23-2013, 11:35 PM
shootnfish
I'm a Mobile 1 fan. It's a full synthetic and I like how it keeps everything clean inside the engine. I haven't used the Quaker State Defy, but I would think if it is a synthetic it should have similar properties.
____________________________________
Red 93 Wrangler YJ Hard Top 5spd 2.5L
31 X 10.5 BFG AT T/As - 15 X 10 Rims - Rancho RS5000 Shocks - Rancho Steering Stabilizer - Air Conditioner (when its 116 here in Phoenix you wont object) - Kargo Master Rack - Hella driving lights - Removed front and rear Track Bars Thrush Exhaust
shootnfish is offline
post #3 of 13 Old 02-24-2013, 01:17 AM
bigbossd1030
I don't do anything other than royal purple or if I take it in, castrol edge.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 13 Old 02-24-2013, 02:18 AM
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Royal purple all the way! But make sure its the kind for older vehicles because it has a lot more ZDDP.
In reply to the original post oil is oil unless it has more zinc/ZDDP which the government is regulating more and more because of emitions. the only thing special about synthetic is that it is filtered more then a normal oil making it lubricate a little better and a little longer.
ashland82391 is offline
post #5 of 13 Old 02-24-2013, 08:18 AM
nembudonna
I go with Casteral. But it's really your call on this one.
nembudonna is offline
post #6 of 13 Old 02-24-2013, 08:57 AM
rescue7
Rotella T6 5w40. It's a full synthetic HDEO (heavy duty engine oil). It has plenty of zinc, and will keep your engine plenty clean. It can be had for 22.00 for the big jug. However, their big jug is only 4 quarts. Another good option is the Chevron Delo 400 LE full synthetic. It is 19.00 for the jug and is a 5w40 also.
Check out bobistheoilguy.com if you have any questions about your Jeep. Ultimately, any good SN rated oil will be great for your engine. Regular Pennzoil Yellow bottle conventional is one of the stoutest conventional oils out there, and performs excellent in our Jeeps. Stay away from Mobil 1, as it increases the iron wear by a significant amount. Plenty of Used Oil Analysis' to back it up. Good luck to you!
rescue7 is offline
post #7 of 13 Old 02-24-2013, 09:33 AM Thread Starter
chuck172
I believe 10w30 is the recommended weight.
chuck172 is offline
post #8 of 13 Old 02-24-2013, 09:46 AM
rescue7
You can run 1030, but the 2.5 and 4.0 prefer heavy oils. Thick 30 weight oils or a good 40. It's cold in Ohio, so I run the 5w40. I will run another cycle of Rotella, and then maybe a little pennzoil ultra 5w30 to clean things up real good.
Be sure you choose a good filter too. You don't need to go overkill, but a Purolator Pureone, Fram Tough Guard TG16, or you can go the new Fram Ultra Synthetic if you want top efficiency.
rescue7 is offline
post #9 of 13 Old 02-24-2013, 04:03 PM
PA_YJ19
Run the cheapest 10w30 u can find and change it often. Brand is just a preference, ur jeep will run on ne crap u throw at it.
PA_YJ19 is offline
post #10 of 13 Old 02-24-2013, 04:32 PM
ashland82391
Agree, but you should add a zinc addative after each oil change and as previously stated used a good oil filter,i use k&n
post #11 of 13 Old 02-24-2013, 04:34 PM
ashland82391
Ps make sure you use 5w30 in cold weather. Start up is the hardest on your engine so you want as much oil flowing asap
post #12 of 13 Old 02-25-2013, 12:22 PM
Mywrangler94
I use Castrol GTX 10w30 in the winter and 10W40 in the summer.... never had a problem. As far as the filter goes...a good name brand is sufficient. I will not use a Fram, as they are great. So good as a matter of fact, that they clog twice as fast. This is a case of too much of a good thing.......Just me.. But then again, I change my oil every 2 months, regardless of mileage.
Mywrangler94 is offline
post #13 of 13 Old 02-25-2013, 02:56 PM
ashland82391
just my opinion but it's not a good idea to run thicker weight oil then recommended. 30 weight is recommended because that is what the engines clearances call for.if the oil is too thick it has a harder time traveling through the spaces resulting in less lubrication which causes faster engine wear.
Also, it should be the other way around, change the oil based on millage regardless of time (to an extent) the more miles on the oil the more the additives in the oil are broken down (oil is 20% additives and 80% oil)
Just my 2€
