Quadratec Ultimate Floor Liner - JeepForum.com
post #1 of 8 Old 03-23-2010, 06:35 AM Thread Starter
JTR2008
So I was thinking about getting a set of these but they don't show a picture of them in a YJ. I was wondering if anyone had these and if they liked them. Also pictures would be great.
Search Results - Quadratec
JTR2008 is offline
post #2 of 8 Old 03-23-2010, 09:21 AM
timatoe
timatoe's Avatar
I don't have those, but if the YJ ones are as thick as those in the pic it'll interfere with pushing the gas pedal down all the way. I had some similar and ended up taking them out.
timatoe is online now
post #3 of 8 Old 03-23-2010, 09:22 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Umm better rip the carpet and apply Herculiner or Rhino Lining...
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #4 of 8 Old 03-23-2010, 01:13 PM
Sharkbike
I got a set of these after welding in a new floor pan. They fit perfect and don't move around. Still, they go in and out quickly and easily. They swallow all the crud that comes off your boots (mud, salt, dirt), then you pull the mat and throw the crud outside. The floor stays clean and dry. They have texture on the bottom that allows air gaps so that any errant water can dry quickly. They work fine with all 3 pedals and there is no interference at all.
I was planning to do a Herculiner job, but after I got these I decided to skip it. The only problem is that there is no backseat version for the YJ.
Sharkbike is offline
post #5 of 8 Old 03-23-2010, 01:58 PM
YJJenkins
1987 YJ Wrangler
Those look pretty beastly as far as floor mats go.
IMO Save up and herc the tub!
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Originally Posted by Couchrider View Post
YJ parts don't fit my YJ right.
Originally Posted by flame0086 View Post
When your realize there is no such thing as AA for jeep owners ;)
YJJenkins is offline
post #6 of 8 Old 03-23-2010, 03:06 PM Thread Starter
JTR2008
I'm planning on getting the tube Rhino Lined this spring after cutting out the drain holes in the floor, they're rusting all the way threw. I figure the mats would look a lot better than the uncovered tube plus when i get an inch of water on the passenger side on a rainy day it'll be a lot easier to get it out.
JTR2008 is offline
post #7 of 8 Old 03-23-2010, 03:14 PM
merckx9
I have Husky liners and love them but I bought them years ago before the Qliners came out and when the Husky version was cheaper. I used to get water like that too and then I changed my cowl rubber under the windshield and it helped big time. The other thing to consider is that Husky offers the rear floor version for YJ's and Q does not in the catalog.
When I was 20 I knew everything, when I was 30 I knew something, at 40 I know nothing!
merckx9 is offline
post #8 of 8 Old 03-23-2010, 05:18 PM Thread Starter
JTR2008
I need to look into getting my water problem fixed. thanks for the advise. I took a look at the Husky liner and not bad but I think I'll go with the cheaper.
JTR2008 is offline
Quadratec floor mats jeepinmichguy_ Wrangler General Discussion 5 11-01-2009 05:45 PM
Quadratec Brand Rear Floor Liner Nick B TJ Wrangler Technical Forum 2 10-04-2009 07:33 PM
Quadratec Rear Cargo Liner - 2 Door spyglass JK Wrangler Technical Forum 0 07-07-2009 04:19 PM
Quadratec Floor mats! A1A-LJ TJ Wrangler Technical Forum 61 07-01-2009 02:00 PM
Is DPG's Ultimate Wrangler kit available on Quadratec? usurp TJ Wrangler Technical Forum 9 05-01-2008 06:54 AM
