putting lift shocks on a jeep with only 1 inch suspension lift - JeepForum.com
post #1 of 7 Old 07-24-2013, 02:08 PM Thread Starter
Xzero117
my jeep is stock height with 1 inch lift shackles and stock springs and a 1 inch body lift
the shocks i want only come in stock height and 3-5 inch lift
what were to happen if i put the lift shocks on my jeep with just 1 inch of suspension lift ?
Xzero117 is offline
post #2 of 7 Old 07-24-2013, 02:27 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
You'll bottom them out and ruin them. Worst case.
Best case you'll bottom them out, and the ride will be horrible.
Michaelgoesrawr is offline
post #3 of 7 Old 07-24-2013, 02:36 PM Thread Starter
Xzero117
I guessed as much
how about using stock height shocks with just 1 inch of suspension lift ?
Xzero117 is offline
post #4 of 7 Old 07-24-2013, 02:42 PM
XJ93
You might overextend the shocks if you go stock shocks with 1" suspension, all depends on the brand and stroke for the shock.
XJ93 is offline
post #5 of 7 Old 07-24-2013, 03:07 PM
Michaelgoesrawr
This. But I'd rather go stock shocks instead of lift shocks.
post #6 of 7 Old 07-24-2013, 03:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Stock length shocks would be the better route of the two but the proper procedure starts with flexing the suspension and measuring the length shocks you'll need when the suspension cycles. That's collapsed and extended lengths plus an inch either way.
Luck Favours The Prepared
Anticanman is offline
post #7 of 7 Old 07-24-2013, 03:29 PM Thread Starter
Xzero117
I guess i'll go with stock height
I bought some cheap monroe about a year and a half ago for 110$ that seems to be holding up fine with the 1 inch shackles
on the other hand I still have my sagging 23 year old stock springs that are completely flat
hopefully the new bilsteins i'll be ordering can deal with new stock springs and 1 inch shackles
Xzero117 is offline
