Putting leaf springs on yj - JeepForum.com
post #1 of 23 Old 07-15-2013, 09:29 PM Thread Starter
Mattias25
So I'm having the hardest time getting those suckers on, any advice or ideas
Mattias25 is offline
post #2 of 23 Old 07-15-2013, 10:05 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
What exactly is your issue with getting them on installing springs on a Yj is child's play. Changing the oil is harder then swapping springs
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 23 Old 07-15-2013, 10:30 PM
gunshw301
I would not go that far! But give us a little more info so we can give some advise or suggestions.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #4 of 23 Old 07-15-2013, 10:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The combination of floor jack and jackstands makes short and safe work of it.
Luck Favours The Prepared
Anticanman is offline
post #5 of 23 Old 07-15-2013, 11:23 PM Thread Starter
Mattias25
Well i put the spring into the frame mount and put the bolt in, no biggy but the problem is getting it to reach that shackle, i loosen up the shackle but stiil having issues. and any ideas how to remove front springs from the front frame mounts, i dont think i can get a grinder in there between mount and leaf
post #6 of 23 Old 07-15-2013, 11:26 PM
Tom95YJ
Tom95YJ's Avatar
What brand springs are you using ? If its RC they are known to be short
I've always done shackle end first
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 23 Old 07-15-2013, 11:27 PM
bigbossd1030
I used a zip disc as the bolt was seized to that inner sleeve. Then when the head and nut were cut off, I used two pry bars, one to open the mount a slight bit and one to pry the spring down. It didn't take much and the mount returned to its original position, so I don't think I caused any damage. Plus I did that a while ago, maybe a year. Still all fine. This may help.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 23 Old 07-15-2013, 11:30 PM
bigbossd1030
This
X2
I did shackles first as well, it just happened that way, it wasn't my plan. But I also used a floor jack and a pry bar. Floor jack to lift it to position and the pry bar to help coax it into place.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #9 of 23 Old 07-16-2013, 10:59 AM
Rproject
1987 YJ Wrangler
You may not be able to get a grinder in there, but how about a sawzall? That's how we got the shackle bolts out of our first YJ.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #10 of 23 Old 07-16-2013, 11:04 AM
grandboost98
Ive used a floor jack between the spring and frame to line it up with the shackle
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #11 of 23 Old 07-16-2013, 02:08 PM
XJ93
I used a cutting torch, cut the eye in half on each side, used a bfh to pound it out of the mount. Then installation of the new springs was a piece of cake, and yes do shackle end first, makes lining things up go much smoother. Question is, did you put new bushings in your front shackle? Mine were pretty bad and wouldn't move, I replaced them and poof things got better.
XJ93 is offline
post #12 of 23 Old 07-16-2013, 06:52 PM
fratis
fratis's Avatar
If you are putting new springs in and your shackle can't freely swing to meet the spring then you are doing only half the job.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #13 of 23 Old 07-17-2013, 11:34 AM
Siva283
I replaced all the bushings when I did mine. The ones in there were 20 years old. Sounds like you need to do the same. Then I bolted up the main eye and could lift the other side of the spring up by hand and swing the shackle to line up. If you prep right its nothing to do a spring in about 30 minutes a peice.
Ask me how I know...
Siva283 is offline
post #14 of 23 Old 07-17-2013, 06:41 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
You'll soon learn that there is always more to a Jeep job than the Jeep job. In your case, the new springs job usually means a new bushing job.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #15 of 23 Old 07-17-2013, 08:03 PM
Rproject
1987 YJ Wrangler
I find it interesting that so many recommend doing the main eye first. I did the spring eye first as it is easier to align a movable object to a fixed object than it is to align two movable objects.
1996 White ZJ
Rproject is offline
