putting gas in is a b**** - JeepForum.com
post #1 of 18 Old 05-06-2010, 12:54 PM Thread Starter
celticluck713
so once again i went to put gas in today and i live in jersey so the attendant was putting it in and the pump just kept clicking off so i was like i got it and filled it myself i hate it anyone else have this problem any fix?
celticluck713 is offline
post #2 of 18 Old 05-06-2010, 12:59 PM
offroadjoker
I used to have this problem with my old camaro, I found that when you pull the nozzle out about a inch or two to break the vacuum that occurs inside the tank, it will not happen.
offroadjoker is offline
post #3 of 18 Old 05-06-2010, 01:12 PM
Allen52105
exactly ... or just do a TJ fillers swap and go to the side of the vehicle
jason
Allen52105 is offline
post #4 of 18 Old 05-06-2010, 01:17 PM
EABiker
Keep the nozzle at a 7:00 position, pulled out about an inch, should fill fine!
EABiker is offline
post #5 of 18 Old 05-06-2010, 02:05 PM
95wrangler4life
x2... 10char
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #6 of 18 Old 05-06-2010, 02:42 PM
Fhajad
Either you're sticking it in too far or your vent line is kinked. (I know mine is, I have to undo it and fill up, kind of a pain...)
Fhajad is offline
post #7 of 18 Old 05-06-2010, 05:56 PM
AZoriginal
I wonder if this problem has to do with the 10 inch vent pipe Jeep installed in our tanks to make the 20 gallon capacity plastic tank only accept 15 gallons.
I say this because this week I had to install a new 20 gallon plastic tank (for other reasons) that doesn't have the vent tube sticking down into the tank. I also replaced the filler and vent hoses from the gas cap. When I filled it up for the first time I didn't experience any problems of the past. Before with the old 15 gallon tank a fill up was a very frustrating process as described by "celticluck793".
If you want to modify your tank (it will work on a 94) it's fairly easy to remove the 10 inch tube. Here is a write up:
15 to 20 gallon modification
Never, Never, Never Give Up
Winston Churchill
AZoriginal is offline
post #8 of 18 Old 05-06-2010, 06:22 PM
FOURWALLYS
Mine is different at every freaking station. At one place it will click the whole damn tank, in another I have to hold it sideways in one direction, another station the opposite direction. The thought of being to stick it in and walk away makes me laugh. I now have the back of a 74 year old woman.
I have a love/hate relationship with my jeep. I love it, it hates me..........
FOURWALLYS is offline
post #9 of 18 Old 05-06-2010, 06:24 PM
MukYJ
MukYJ's Avatar
Leave Jersey so you can pump your own gas?
I've done the 15-to-20 gallon mod and I've found that mine works best if I hold the nozzle at the 4 o'clock position and pulled out about an inch.
Some pumps are MUCH more sensitive than others, so if you find one that works well for you make note of it.
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
post #10 of 18 Old 05-06-2010, 06:41 PM
ZeroGravity
First of all I suggest getting a length of chain or even string and make something that will hold your plate open.
I am a gas station attendant and I have not had more problems trying to fill up anything compared to my YJ. I don't know how NJ is, but try to find a gas station that doesn't have the rubber boots over the nozzles. Try asking if they have a tool that holds the rubber boot back. I usually use it when I bikes come in or I'm filling up gas cans that I can't stick the nozzle into. Your best bet would be to relocate it to the side or move your license plate.
Oh, I should also mention that attendants appreciate tips for that kind of work
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #11 of 18 Old 05-06-2010, 07:48 PM
Fhajad
In Indiana, we don't have those weird things.
Or free bumpers...
Fhajad is offline
post #12 of 18 Old 05-06-2010, 07:56 PM
Meiacanthus
The lid holds the plate down if I need it to. Otherwise, it's a two handed job LOL I also have to pull it out about an inch to bypass the clicking problem. Some nozzles need to be turned a bit, but mostly you just gotta figure out the depth. I was told by a someone at the Chevy dealer that it's because the the gasoline backs up too fast, so the sensor thinks the tank is full, so it clicks off. My Cobalt used to do it before I got the Jeep.
PS what kind of ***** lets the attendnat fill his gas tank? LOL
Meiacanthus is offline
post #13 of 18 Old 05-06-2010, 08:00 PM
trw
2011 JK Wrangler
Just you wait, mine worked fine for a while after I did this mod, but it is now back to doing it again over a year later......
Does anyone else find it funny you have to do this "magic trick" just to fill their Jeep up? it makes me all fuzzy inside about YJ ownership.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #14 of 18 Old 05-06-2010, 08:15 PM
paxcrunner
In Jersey its illegal to pump your own gas. And give tips to the gas guys
paxcrunner is offline
post #15 of 18 Old 05-06-2010, 08:26 PM
CSCmrwizard
1982 CJ5
i found that if your wife drive your jeep make shure its almost at E no pain that way
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
Putting AW4 in 95 YJ Canfourjeep YJ Wrangler Technical Forum 3 04-27-2009 12:08 PM
Putting a 454 in my YJ dbartrom YJ Wrangler Technical Forum 4 07-03-2008 04:57 PM
Putting in a fan bryris YJ Wrangler Technical Forum 1 04-19-2006 12:51 PM
? on putting the top down DaveAnderson YJ Wrangler Technical Forum 5 08-22-2005 12:47 PM
putting in a new 4 cyl...what oil? CB4 YJ Wrangler Technical Forum 1 07-20-2004 07:01 PM
