Putting fuel injection BACK on 1993 4.0 - Page 2 - JeepForum.com
post #16 of 18 Old 09-16-2013, 12:04 PM Thread Starter
fishtruck
1987 YJ Wrangler
So on my Jeep, when the replacement 4.0 showed up without fuel injection, I am thinking the PPO just bolted on a 258 manifold with a weber carb. Would it have as simple as that?
fishtruck is offline
post #17 of 18 Old 09-16-2013, 12:25 PM
Que89YJ
Yep, thats it. Manifold and the other stuff and you will be running a MPFI.
Que89YJ is offline
post #18 of 18 Old 09-16-2013, 01:05 PM
skyj
Yep you just need everything thing I have to convert back to FI plus figuring out the wiring. hopefully it has the 4.0 flywheel so you wont have to pull the motor that should be easy to check.
build thread:
skyj is offline
