purge canister ? - JeepForum.com
post #1 of 6 Old 10-16-2001, 08:19 AM Thread Starter
glm 87 wrangler
purge canister ?
Yes it that time of year again.Inspection!got away with it last year this year will be harder.won a purge canister on ebay.thats the caister that holds the unburned fuel.I need to know were it bolts to.Thought I knew but i was wrong,pics would be great Or tell me were it goes.Oh by the way, I have 4.2 258,dont think it the same as the 4 bangers.So all you 258 out there please reply would be greatfull
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #2 of 6 Old 10-16-2001, 04:38 PM
grantnps
Where do you live. In Oklahoma, a law passed banning inspections.
'94 YJ 4 banger :( 4" ProComp suspension 32x12.5 a/t's, flow's, kn air filter charger, and lots of little appearance mods.
grantnps is offline
post #3 of 6 Old 10-16-2001, 04:58 PM Thread Starter
glm 87 wrangler
NO wish that were true in my state.Some states you got to pass a sniff test, but not in mine.The only thing in mine, what was on it stays on it smog control that is.Had a guy that got a sticker for me but has since move cant find him.Just would like to know were it was
mounted before so know one would know it was removed before and starts looking closer to
see what else maybe missing.If all else fails will stick it any were but would like to put
back were it was. It maybe missing a bracket dont know really it was removed before i got it.
post #4 of 6 Old 10-16-2001, 05:19 PM
iJeep
drivers side firewall in the corner
iJeep is offline
post #5 of 6 Old 10-16-2001, 05:36 PM Thread Starter
glm 87 wrangler
Thanks that what i was thinking but wanted to make sure,Just thought it would be a tight fit.Also thought there was room on the pas.side, but wanted to be sure thanks alot..
post #6 of 6 Old 10-16-2001, 07:46 PM
mikeyjph
Just a thought, every year I turn my idle screw WAY down, like around 300 rpms at idle,and it passes emissions fine.
mikeyjph is offline
Does a 4.0 Require a Vapor Canister or Purge Valve to run? stopthevoices77 Wrangler General Discussion 0 10-29-2008 10:06 PM
Evap canister purge solenoid loud fish4life TJ Wrangler Technical Forum 6 03-08-2008 07:49 AM
Transmission power purge plus Mattholomew TJ Wrangler Technical Forum 2 01-19-2007 04:22 PM
Evap Purge Solenoid SCHMEOW YJ Wrangler Technical Forum 0 12-28-2006 09:44 PM
01 TJ Incorrect Purge Flow Stasis TJ Wrangler Technical Forum 3 06-08-2004 04:53 AM
