Pure Monkey-Business Build - JeepForum.com
post #1 of 25 Old 01-29-2012, 12:51 AM Thread Starter
mrmonkey
I've never had a car I thought was worthy of a build thread. But I thought it might be fun to track my progress on this one. This will definitely be a slow build, but I thought I'd share the pics.
About 4 months ago my wife's car died and it was time to look for a new car. We decided to look at Jeeps because that was my first car in high school, and it was her "dream" car. Unfortunately it was hunting season and Wranglers were going faster than you could call about them. We finally found a 2.5 L 93 YJ that we both seemed to like. It wasn't a 4.0... but we could deal with it. We knew it would need a little work and money to get it to where we wanted it to be.
First things to do: lift it and get rid of that ugly hard top. Check and check.
I got a new Bestop Supertop, neoprene seat covers, and did an SOA conversion. I don't have any pics of it sitting flat, but these are a couple flex shots after the conversion. I've still got a few more things to finish up from the SOA like the SYE and high steer. But for now it's doing fine. I've got the SYE in my garage, just need time to install it.
Everything has been running great until last week. My wife was driving it on the freeway and it overheated on her. I don't think she noticed until it was too late. She was on the side of the road on the freeway and tried to drive it off the freeway to park it somewhere. The next morning we went to pick it up and it was toast. Zero compression on cylinder 3 and it failed a leak test... so it was time for a rebuild or replacement.
Fortunately it was a great time to look into better options. If I was going to drop money into it to replace an engine, I was going to ditch the 4 banger. I started looking into several options. I was considering a Ford 5.0L, also looked at buying a Chevy Blazer to pull everything from, and several other options. Then the other day I came across a trashed Cherokee for sale for $600. It's a 95 with the 4.0L HO/AW4/NP231/and the Chevy 8.25... too good to be true. I went up there today to drive it and bargain with the guy. The car is trashed. The steering box broke off the frame and the steering was insanely loose, every wheel bearing needed to be replaced, the interior was torn to pieces by a dog, the body was all smashed, somebody had had some fun with extra wiring, brakes were gone, etc. The engine ran strong as could be and has 172K(not awesome, but not terrible) and the AW4 had been rebuilt 60,000 miles ago. The car was meant to be an organ donor. Between the parts I pull from my Wrangler and the left overs from the donor I can easily make my money back. I talked the guy down to $550 and drove it home. I'll break-even at worst.
I'm trying to decide if I want to move to the AW4 or keep searching for an AX15. I know my wife would love the auto, but I'm not sure what kind of shift housing I'll end up with on the floor of the wrangler. It probably won't be pretty. What do you all recommend? If I could find a steering column from a YJ with auto tranny that would be ideal... but that would also mean more work.
This week will be mostly focused on the transplant. Then the plans will be installing the C8.25, maybe stealing some leaves from the XJ pack to add to my stock YJ pack, install the SYE and new drivelines, and then throw some 33's under there.
I know my rig doesn't compare to the other builds on these forums, but I thought I'd share if anyone cares.
Can anyone give me some ideas of what an auto tranny might look like installed on the floor?
mrmonkey is offline
post #2 of 25 Old 01-29-2012, 09:30 AM
SnowYJ
1988 MJ Comanche
Looks pretty good! nice score on the donor.. Personally i would pluck what you want from the Cherokee and resell it!
I go to college and I drive a Jeep.
SnowYJ is offline
post #3 of 25 Old 01-29-2012, 10:43 AM
Fuddmaster
Yea nice but on a donor! I will be watching this to see how you do the auto!!! I'm in tHe process of doing research for a v-8 magnum swap and haven't decided on a tranny yet! Good luck keep us updated!
Fuddmaster is offline
post #4 of 25 Old 01-29-2012, 12:43 PM
monkeyhouse
Are you just monkey-ing around? lol. Personally, I would look for an ax-15 setup, but since you already have an aw4, go for it. It should be pretty easy to find the floor shifter setup somewhere, and allot less work than installing a column setup.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 25 Old 01-29-2012, 12:57 PM
dodger889
Why not use the shifter out of the XJ??? It would not take much work to get it out fab a mounting point. then use the TC shifter from the YJ then you are all set. You do realize that you are going to need to move the engine mounts on the frame.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 25 Old 01-29-2012, 03:07 PM Thread Starter
mrmonkey
Thanks for the comments. I got a pretty good deal on the donor. And after I'm done with all of this I'll have an AX5, NP231, D35, a blown 2.5L, 2 new tires, and then whatever I can get for parting/junking the car. I think i'll probably break even on all this. Which is awesome.
Yeah I am aware I will have to move the engine mounts. What is the best way to do that? Are the mounts from either the 2.5 or the new 4.0 reusable? Or would I be better to buy some new ones?
I have thought about just using the whole shifter from the XJ. I'm not sure how nice it'd look though. Not a huge deal. Anyone have pictures of that kind of setup?
mrmonkey is offline
post #7 of 25 Old 01-30-2012, 03:24 PM Thread Starter
mrmonkey
Here are a couple photos from the swap going down today. Hope you enjoy. Sorry about the quality, from a camera phone.
With everything out.
The new guy... getting ready to move in.
Might as well power wash everything while we're in there.
Just trying to decide what to do next with the motor mounts. Apparently Jeep has discontinued the item. I could order some in and wait 3 days for shipping, or we could hack off the old ones and move them. Any recommendations?
I'm ready to go wheelin!
mrmonkey is offline
post #8 of 25 Old 01-30-2012, 04:21 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
Give these a go he is a member on the site located in the vendor section
Back Road Jeepin
BackRoadJPin is offline
post #9 of 25 Old 01-30-2012, 04:34 PM Thread Starter
mrmonkey
Thank you. I'll see how these mounts come off... If not I'll order a set.
mrmonkey is offline
post #10 of 25 Old 01-30-2012, 05:47 PM Thread Starter
mrmonkey
Here are a couple before and after of the power wash.
Before:
After:
That's a lot better.
mrmonkey is offline
post #11 of 25 Old 01-30-2012, 06:02 PM Thread Starter
mrmonkey
I need a new set of U Bolts for the spring packs. When I did the SOA I couldn't find a set. But now that I'm doing the Chrysler 8.25 it might be a good chance to replace the fronts too.
Where do you guys recommend a set of U Bolts for the D30 front and Chrysler 8.25 rear?
Thanks.
mrmonkey is offline
post #12 of 25 Old 01-30-2012, 06:06 PM
jmmorgan82
2009 JK Wrangler
That is an interesting looking hard top. Any brand markings on it?
jmmorgan82 is offline
post #13 of 25 Old 01-30-2012, 06:49 PM
MUDDYJEEP
"Just trying to decide what to do next with the motor mounts. Apparently Jeep has discontinued the item. I could order some in and wait 3 days for shipping, or we could hack off the old ones and move them. Any recommendations? "
If I remember right, and you're talking about the mnts welded to the frame, the 2.5L mnts have a different center to center where the mnts on the engine lineup and different angles on the flanges since they will mount further forward on the frame, just stuff to deal w/ if not buying new. The only thing I salvaged from the frame mnts was the piece welded to the underside of the mnt (new from the factory don't come w/ this piece, not sure if its really needed)
MUDDYJEEP is offline
post #14 of 25 Old 01-30-2012, 11:33 PM Thread Starter
mrmonkey
Yeah I've never seen another like it. It was unique because you could use those hard angled soft windows with it and it sealed up nicely. But no,I never found any markings on it.
mrmonkey is offline
post #15 of 25 Old 01-31-2012, 07:38 AM
dodger889
If i was you I would order new motor mounts from jeep this way they fit properly. Or find someone that has a set. Trying to use the ones that you cut off might not fit properly.
4.0 swap , build thread , soa
HP 30 rust monkey crusher242 TJ Wrangler Technical Forum 6 04-24-2009 12:37 AM
Project Green Monkey...a.k.a. Project Empty Pockets - '97 TJ Sport build thread Poobah TJ Wrangler Technical Forum 20 12-14-2008 09:30 PM
im about to go for pure looks... paroxysym TJ Wrangler Technical Forum 5 02-03-2006 04:09 PM
Grease Monkey Steveqvs TJ Wrangler Technical Forum 8 12-01-2002 05:30 PM
I want to be a grease monkey JPJeep TJ Wrangler Technical Forum 1 08-30-2002 09:44 AM
