Pulse wipers not pulsing - JeepForum.com
post #1 of 8 Old 06-16-2001, 03:05 AM Thread Starter
dalemac
So some of us have to live in the rain forest and to top it off now my wipers stopped with the intermitant option. I got the mist action for one swipe and the full on but no pulse. My manual says there is a module that controls this but I haven't found it yet.
Anybody know where this thing is and what it looks like?
Help
89 YJ, brand new to the family, working on basic mechanical stuff first. Bigger plans for later but don't tell the wife.
dalemac is offline
post #2 of 8 Old 06-17-2001, 12:09 AM
lostboy
It's under the dash near the steering column...it's a black box between the harness from the wiper control on the column and the wiper motor...before you replace it..69.00 at the dealer....try cleaning the wiper potentiometer inside the column(at the end of the shaft which enters the column)contact clean with the tube can get in there...or you'll have to remove the steering wheel to get to it which I did only cause I was replacing the turn signal harness...if that doesn't work ...drill out the rivets of the control unit and check for any failed components inside...I was lucky...just a couple of broken solder joints..repaired them and it was good as new...put hte unit case back together with some small screws and nuts...hobby store item...good luck
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #3 of 8 Old 06-17-2001, 03:10 AM Thread Starter
dalemac
Thanks for the tip on the potentiometer in the column. I'll check that out. But under the dash I found a black relay that turned out to be the horn relay. I did find, stuffed way up behind the parking brake, a tin can type component that measures approx 1"x2"x2" with five connections. The wires disappear into a harness and I've not had a chance to check for power and stuff here yet. From your description this doesn't sound like it though.
dalemac is offline
post #4 of 8 Old 06-17-2001, 10:19 PM
lostboy
you're right ...that's not it ....it's attached to a harness that exits the bottom of the steering column....I think mine is just velcroed to somewhere under the dash.
lostboy is offline
post #5 of 8 Old 06-17-2001, 11:37 PM Thread Starter
dalemac
Hmmm, I found a circuit directly out of the column that has a broad plastic connector on it with 7 wires and when it's unplugged the wipers don't work at all, so the component that your referring to must plug in inline...like with a male plug and female plug type connection. Am I getting close? If so then in my case it is missing all together.
dalemac is offline
post #6 of 8 Old 06-23-2001, 02:51 AM
lostboy
that's the one ,,it's a box that measures about....workin from bad memory here.. 1 1/2 x 3 inches and has a plug at either end
that other one ya found ..i had one too...all rusted ..still don't know what it was for...but I think it may be some kind of fog light relay...the fog lights were stripped from mine
lostboy is offline
post #7 of 8 Old 06-24-2001, 04:59 PM Thread Starter
dalemac
OK, thanks for your help Lostboy. Now I know for sure why the wipers aren't pulsing and I'll check out the wreckers and stuff to get a replacement.
dalemac is offline
post #8 of 8 Old 06-26-2001, 02:11 PM
bluebellyday
This is a good topic and must be an ongoing wrangler problem. My 95 is the same way. I think you solved mine also. thanks
bluebellyday is offline
Pulsing vibration at 60+mph BoarderX47 TJ Wrangler Technical Forum 7 11-22-2012 02:27 PM
engine pulsing cosmo_j YJ Wrangler Technical Forum 18 12-29-2009 11:21 AM
Pulsing Vibe from 50-60 mpg missionAvs TJ Wrangler Technical Forum 10 12-04-2009 12:01 AM
94 2.5 engine pulsing? Shawn94 YJ Wrangler Technical Forum 1 08-31-2009 08:57 AM
Steering pulsing rick_chicago YJ Wrangler Technical Forum 2 05-07-2002 08:14 AM
