Pulling the trans out of a 95 - JeepForum.com
post #1 of 5 Old 09-05-2011, 01:42 PM Thread Starter
msprooch
I have a 95 YJ with the 2.5 and an ax5 and I'm trying to remove the transmission so that i can install a new clutch. I have my transmission jack under it right now but it does not want to slide out. All the bolt to the engine block have been removed and all the sensors, wires, and the breather hose have been disconnected. I have a jack stand under the oil pan of the engine. Also, the sifters and boots have been removed. And the external slave is out.
So my question is what could be holding it up? Do i need to take the starter out?
Thanks guys!
msprooch is offline
post #2 of 5 Old 09-05-2011, 01:47 PM
Budke
Taking the starter out is a good idea. You don't want to rip all those wires out.
Did you unbolt it from the fly wheel?
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #3 of 5 Old 09-05-2011, 02:17 PM Thread Starter
msprooch
At this point Im just trying to get the transmission apart from the engine.
msprooch is offline
post #4 of 5 Old 09-05-2011, 03:03 PM
87YJerryRig
1987 YJ Wrangler
You may have to use a large screw driver and pry the transmission loose where the guide sleeves are on the sides of the bellhousing
87 YJ - Slowly making redneck modifications...
87YJerryRig is offline
post #5 of 5 Old 09-05-2011, 03:08 PM Thread Starter
msprooch
I got it...it was the metal shield that covers the bottom front of the bell housing. Two little screws, after those were out it slide right back.
Thanks guys.
msprooch is offline
feasible to swap the 42RLE automatic trans. for a manual trans?? RUGBYBOY TJ Wrangler Technical Forum 2 12-21-2010 10:24 AM
Questions about pulling engine and pulling distributor as well as other parts... Goobersbro YJ Wrangler Technical Forum 13 05-13-2010 12:51 AM
automatic trans bleeds trans fluid in 3rd gear if i drive over 60 mph GIJIM TJ Wrangler Technical Forum 2 08-13-2008 07:43 AM
Pulling BA-10/5 trans but now stuck on stripped bolt spshultz YJ Wrangler Technical Forum 16 07-12-2008 12:22 PM
Pulling trans ? about clutch 94Wrangler4.0 YJ Wrangler Technical Forum 4 09-03-2005 08:34 PM
