pulling right in 4wd - JeepForum.com
post #1 of 6 Old 03-26-2002, 08:25 PM Thread Starter
jeeping18
Sorry guys, kinda a long story.
i have a 91 YJ and just had 3:73's done and noticed a problem(not sure if the gears have anything to do with it)but i pushed it into 4Hi the other day on the highway and it pulled really bad to the right. it is fine in 2wd but only pulls in 4. i have always shifted this jeep on the fly and was just now told not to because of the vacume system, it never gave me and problems untill i had it re-geared. if you have any info id appreciate the help!!!!
thanks
1991 YJ
-4.0L I6
- BORLA CAT BACK EXAUST
-2.5 INCH PRO-COMP LIFT
-31X10.50 PRO-COMP MUD'S
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
jeeping18 is offline
post #2 of 6 Old 03-26-2002, 08:31 PM
evilpsych
evilpsych's Avatar
first off.. you shouldnt be using 4wd on the highway.. you will destroy your transfer case.. only offroad or on slick surfaces should you use 4wd..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 6 Old 03-26-2002, 08:39 PM Thread Starter
jeeping18
evil, thanks alot. i live in ohio and it was snowing like hell and i would call that a (slick surface). if you have any HELP for me id like to hear from you again.
1991 YJ
-4.0L I6
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
post #4 of 6 Old 03-27-2002, 10:39 PM
renegade0351
jeeping i have the same problem, also after regearing to 4.56's , pulled to right in snow {before the regear no problems} some guys here told me the left side may not be engaging. still havent solved the problem but if i find anything out i'll pass on the info.
89 sahara, 4.2 , k551 weber, nutter bypass, tuffy stereo security console & under seat security drawer, 4'pro comp & 3'body, front waggy44 w/detroit & 4.88, rear waggy44 w/detroit & 4.88, teralow sye, tw's cv drive shaft {rear}, warn locking hubs, boomerrangs all around, 35x15.50 tsl-sx swampers { love that roar}.
renegade0351 is offline
post #5 of 6 Old 03-28-2002, 10:27 AM
89 YJ
Dunno guys, u got me stumped on that one! Only thing i can say is maybe make sure tire pressure is same in all tires. If the right front is lower it will pull that way more in 4wd. O and doesnt the vaccume shifter engage the right front when it shifts? So if it isnt shifting the axels together id think it would pull the other way........
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
post #6 of 6 Old 03-28-2002, 07:58 PM Thread Starter
jeeping18
i checked my tire preasure first thing and they are all the same. i also lifted my front end and turned my tires, and the axel and spider gears and everything seemed fine. i think im gonna get into it friday and tear it down. ill keep you updated.
1991 YJ
-4.0L I6
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
Pulling a Jet-Ski mferrari TJ Wrangler Technical Forum 23 06-28-2016 11:15 AM
Pulling to the right RUBtjICON TJ Wrangler Technical Forum 9 02-20-2008 10:15 AM
Pulling A/C J33Pyj YJ Wrangler Technical Forum 9 02-08-2008 07:19 PM
pulling TJ with 4.7L HO WJ? TXST8tj TJ Wrangler Technical Forum 5 12-14-2004 08:50 AM
Pulling my 6 cyl smok3y YJ Wrangler Technical Forum 5 10-30-2003 01:42 PM
