Pulling my 8.8 possibly tomorrow morning couple questions - JeepForum.com
post #1 of 11 Old 05-15-2010, 07:49 PM Thread Starter
Goobersbro
Okay so my friend wants to go to the junkyard tomorrow to get some stuff so I might tag along and get my 8.8....I called today and the guy told me 130 for the axle and all the other junk...So I'm going to pull the axle and the e brake assembly...The axle is complete so alll I need is everything on the axle and the ebrake assembly.....How much of the E brake assembly do I need to pull....Also what is the difference between the explorer 8.8s and the Ford Ranger 8.8s...
Last question was there a carrier break in the 8.8s...I don't care about what gears are in the one I get due to changing to 4.88s but I don't want to have to buy a new carrier.
My marshmallow build
Goobersbro is offline
post #2 of 11 Old 05-15-2010, 08:08 PM
ugmo
I used the stock e-brake cables per the jedi method, but if you want to go the explorer route then remove the e-brakes at the frame bracket.
As you probably know, it's also best to get new u-bolts but you may want to grab the old stock ones for trail spares.
As far as ranger v. explorer - there is nobody on this board running a ranger 8.8. Nuff said?
Carrier break - don't think there is one but maybe someone else will chime in or you can go to the 8.8 facts page.
ugmo is offline
post #3 of 11 Old 05-15-2010, 08:22 PM Thread Starter
Goobersbro
Okay thanks man that pretty much answers my questions. As for the u bolts I will most likely be cutting them off to save time but I might consider pulling them.
post #4 of 11 Old 05-15-2010, 08:32 PM
Mike
oooh you almost had it
Mike's Avatar
big affirm to ugmo, no carrier break from 3.73 up
Mike is offline
post #5 of 11 Old 05-16-2010, 07:00 AM
I8AHUMR
The Ranger 8.8's are 28 spline shafts versus the Explorers 31...
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #6 of 11 Old 05-16-2010, 11:06 AM
JohndKc
1987 YJ Wrangler
I don't know how much you are looking to spend on the e-brake, but it if i did it again i would buy this--- http://www.4xshaft.com/index.html click to rotor kit.
I know someone on here runs this setup and loves it. You need a plate style SYE though.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #7 of 11 Old 05-16-2010, 11:50 AM
lang1864
2010 JK Wrangler
Yea you definitly dont want the ranger 8.8.
lang1864 is offline
post #8 of 11 Old 05-16-2010, 12:46 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
The only thing you need to worry about is LSD (limited slip differential), if you are going with a lunchbox locker back there. If your planning a full carrier locker, I'd go with an open carrier anyway. Then you can sell it to someone later.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #9 of 11 Old 05-16-2010, 04:21 PM Thread Starter
Goobersbro
Well I didn't pull it today friend wimped out so I'll have to pull it later in the week but I got a ton of grinding done so thats a + As for the Locker I'll be putting an ARB in there so it doesn't matter what carrier It has in it correct??? like because its a full case the locker itself is the carrier correct or am I wrong?
post #10 of 11 Old 05-16-2010, 04:54 PM
RockWoRM
RockWoRM's Avatar
like, you are correct, sir.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #11 of 11 Old 05-16-2010, 05:12 PM Thread Starter
Goobersbro
Okay cool beans yea the guy told me they only have a couple so my selection is going to be limited...I'm replacing pretty much everything on it though besides the axle housing and the shafts....So I don't think it will matter much the gearing or LSD or open
discos tomorrow morning.. write up please? $lick TJ Wrangler Technical Forum 25 11-22-2011 04:34 AM
will be pulling what I belive to be the fuel injection tomorrow have a couple ???'s Goobersbro YJ Wrangler Technical Forum 26 12-06-2009 09:24 AM
buying a 4.2 tomorrow to swap from 2.5, couple questions Floppy YJ Wrangler Technical Forum 53 10-11-2009 06:16 AM
Jeep was pulling hard to the right this morning but not in the evening... Bandicoot TJ Wrangler Technical Forum 4 07-04-2008 11:33 AM
installin my catback exhaust tomorrow, couple Questions first Jeepthang04 TJ Wrangler Technical Forum 15 04-17-2005 08:04 PM
