Puegot BA 10/5 Front input seal - JeepForum.com
post #1 of 4 Old 09-22-2011, 08:01 AM Thread Starter
Berniebikes
Since I've had the jeep there has been an oil leak at the rear of the engine, bell housing area. I assumed it was the notorious rear main seal and put it on my list of things to tend to. About a month ago I put a new internal slave, and when I had the transmission out I noticed there was oil inside the bell housing. When I got it back together the oil leaking out onto my exhaust was definitely the new gear oil I put back into the transmission, no mistaking it for motor oil. The front shaft seal was worn out, allowing transmission oil to leak down the bell housing then out and underneath, right where you would see oil from a rear main seal.
I searched around and finally found a FSM online for the BA 10/5 and pulled it out again, removed the front bearing retainer (5 studs and two bolts, just fits on the front of the transmission case) and put in the $5 seal (lots of work to put in such a cheap part) and went to put it back together. Unfortunately there was some galvanic corrosion around one of the bolts holding the bell housing in place and it stripped the threads out. I'm beginning to hate steel bolts into an aluminum case. Now I'm waiting on the M10 heli-coil to arrive so I can repair it and hopefully fix the leak that has plagued me for so long. The whole job wasn't too bad, but I'm beginning to learn that no matter what you go to do on this 20+ year old machine there will be some twists in the job.
I'm also wondering how many of you have changed out rear main seals when your transmission shaft seal was the culprit??
cheers!
B
Berniebikes is offline
post #2 of 4 Old 09-22-2011, 10:47 PM
444
What you should have done right at the beginning is swap out your ba-10/5 for an ax-15. I thought my ba-10 was "okay" until I found a wrangler with the ax-15 at the junkyard and felt how the shifts are sooooooo much better with the ax-15.
444 is offline
post #3 of 4 Old 09-23-2011, 12:04 PM Thread Starter
Berniebikes
yep, I know but I don't have another $400 or $500 to dump into this pig right now. By the time I get the bell housing, external slave, adapter line, change from the 21 to 23 spline, and get a new pilot bearing plus acquire the AX-15 I'll be out at least out that much. As far as the seal goes I'm only out $5 plus the cost of the Heli-coil and my time. One day when I gather the parts and have the time I'll change over, or whenever the BA-10 blows up and needs major repair I'll change it out. Until then I like $20 vs $500!
post #4 of 4 Old 11-03-2013, 03:21 PM
rtillery34
1987 YJ Wrangler
how did you remove the studs that hold the front plate on?
rtillery34 is offline
Puegot BA 10/5 Front input seal Berniebikes YJ Wrangler Technical Forum 5 03-01-2014 08:39 PM
Ax-5 Input Seal and Bearing sentinal02 YJ Wrangler Technical Forum 16 03-13-2013 06:45 PM
Input Shaft Seal Replacement? Zazoos YJ Wrangler Technical Forum 12 01-29-2012 02:26 PM
Gearbox Input Seal Whooker23 TJ Wrangler Technical Forum 1 07-19-2009 09:49 PM
AX-5 Front Input Seal Replacement-Gasket behind plate snidave02 YJ Wrangler Technical Forum 4 03-10-2009 07:09 AM
