Quantcast PSC power steering pulley help - Page 2 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > PSC power steering pulley help
Old 03-12-2009, 02:31 PM   #16
spiicytuna
SUCCESS! The 2401 pulley solved my problems. I got the new belt on today too after verifying that the pulley was going to work. Quad still swears that the 2411 (listed for a YJ) works on "everyone elses" YJ. I clearly needed the 2401. If you have a 1995, or for that matter any year YJ, and you try this swap and have issues, the 2401 (listed as for a TJ) pulley may be your solution.
spiicytuna is offline   Reply With Quote
Old 03-19-2009, 01:00 PM   #17
spiicytuna
Update: To anyone who does this and has issue with getting a belt that will truly fit; after some trial and error I have ended up going with a Gates Micro-V part#k060695 belt. The "stock" one that I picked up at the local parts store got snug, but not tight and after about 2,000 miles was squealing like a banchee (sp?) ... with the new shorter Gates I can tighten it up and still have room to adjust it whereas before I would have the adjustment screw at max and the belt would only be snug.
Old 03-19-2009, 08:56 PM   #18
jeeepguy
jeeepguy's Avatar
Glad it worked out for you.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline   Reply With Quote
Old 04-29-2009, 10:33 PM   #19
zachjeep
new pulley
thinking about this, just put a transcooler on for the p/s fluid, does the pulley come with new bearings? mine are shot..
zachjeep is offline   Reply With Quote
Old 04-29-2009, 11:22 PM   #20
spiicytuna
It's just the pulley by itself, nothing else.
Old 06-11-2010, 07:57 AM   #21
MARKIS
years later but same problem.
I should have read this in the beginning!! I was so pissed after I got the pulley on because I thought it wasn't going to fit, but after I doubled checked all the #'s on the pulley, I was just figuring it was an illusion and that I would see, once I pressed it on and put it in, that I was just seeing things! So, after it didn't fit, I took my cut off wheel and destroyed my alum bracket trying to make a "round peg fit into a square hole" to make up for the 1/2" of misalignment. I lost!! I'm on the phone (hold for 20 minutes) with quadratec and I stumble across your post! It all made sense than! Apparently this happens with 94' as well as your 95'. It was repeated by the tech at quadratec from PSC that this 'HAPPENS' once and while with these models anyway, I am getting sent a new pulley from quadratec... THANK YOU for your post!!
MARKIS is offline   Reply With Quote
Old 06-11-2010, 09:08 AM   #22
spiicytuna
I know of your pain and frustration very well. Once you get the new pulley, all will be well. Good Luck and be sure to post back.
Glock Forum
