#1 | |
PSC power steering pulley help
I purchased the psc power steering pump pulley after talking to quadratec and them telling me that it would work with my stock pump. My stock pulley was cracked and on its way out so I figured "upgrading" would best vs another stock pulley. I got it last week and I went to put it on today and my bolt and washer trick worked pretty well but only got it on 95% of the way. I thought I would put the belt back on and just see if that was good enough. Nope. It pulled the belt 1/2 way off of the lower pulley. I broke down and bought the $30 pulley installer that would work and installed it the other 5% of the way and I am still having problems with it pulling the belt 1/2 way off of the lower pulley. I know that the pulley is seated as far as it will go because I broke the installer tool trying to press the pulley on further. Does anyone else run this pulley or have any experience with this pulley? If not do you have any ideas? I know pictures tell more of the story that I can ever describe, so see below.
#2 |
Looks like in the pictures that the pump shaft is not flush with the end of the pulley. If the pulley is not flush with the shaft, then you will have the problem that you are having. Either the pulley is too small or the pump shaft is too big. Have you tried to put the old pulley on the new pump?
#3 |
I cant really tell from the pics, and that pully is way diffrent than the stock one. But is there any chance that the pully could be on backwards?
'93 YJ 4.0L, AX-15, NP-231, SYE, CV, 8.8in rear, OME 2.5 lift, WJ knuckle conversion, Warn M10000 winch. Soon to come: Hydroboost and a stroker. '79 Cherokee Chief, 401, T-18/D-20 and hydroboost. Otherwise stock. Future mods:Caddy 500, NV4500, NP205, high pinion D60 front and D70 rear. SOA with 35X12.50's on re centered H1 bead lock wheels. Warn 12K winch. |
#4 | |
Pimp Hand
or it is the wrong pully all together.
___________________________________________ What is all of this talk of Savvily designed products?
#5 | |||
Yea, looks like the pulley is on backwards. The offset is supposed to face the pump body and the fourth pic down shows the pulley hub shoulder facing out and it should be faced inwards.
"Si Vis Pacem Para Bellum" Quote:
#6 |
Krawler
x 2 This the same pulley I use with my PSC steering system. You got`s it on backwards dude.
#7 | ||
I put back on my nearly broken stock one and everything is okay but it will not last much longer so I either (a) have to figure out how to get this one to work or (b) just give in and order a stock replacement
But if I were to put it on the other way then how would I get it off if I ever needed to? The groves that the power steering pulley puller fit into were facing forward the way I installed it. If I put it the other way the groove would be towards the pump. ![]() Yes it is different all around from the stock one. From Quadratec's website: "Smaller than stock pulley - provides better low rpm performance." |
#8 | |||
Think I see what the problem is now. The pulley you have looks like it is a PP-2401 and you should have a PP-2411. The PP-2411 does not have the dish offset on the outer side of the pulley like yours does. Think Quadratec sent you the wrong pulley. I realize its stamped 2411 but I'd still check with PSC.
You should be able to verify that tomorrow morning by calling PSC tech support. 817.270.0102 Ask for Kelvin
#9 | |
![]() ![]() When I get the new pulley, we'll see what happens. I just want it to work!!Last edited by spiicytuna; 02-23-2009 at 01:05 PM.. |
#10 |
Update:
Got the replacement finally today. Pix below. I will install and let everyone know what happens. ![]() |
#11 |
Just out of curiosity, whats the benefit of this and how much was it?
4.2 EFI - Pacesetter header - Flowmaster - 4.5" RE XD - RE Monotubes - 35" Trxus M/Ts - 4.10s - D30 Aussie - 8.8 Trac Lok - NV3550 - Centerforce Dual Friction - B&M Shifter - ARB Snorkel - Livewires - M8000 - Duralined interior - custon front bumper - custom brush cables - HiLift on the hood with lights "Don't follow me, You won't make it!" |
#12 |
looks like that belt is pretty hammered too, im sure thats not helping your issue. That pulley is supposed to help keep the pump cooler ? is that the idea ? or is it an underdrive pulley?
#13 |
that belt got chewed up cause the pulley was forcing it to run 1/2 cocked
the basis behind that pulley... its smaller in diameter, meaning, it will spin faster at idle and help pump more fluid,,, for cooling the pump, and pump more fluid making steering lighter/easier to turn.. im also looking into this option at the moment,,
[COLOR="darkred"][COLOR="blue"]My Daily Driver... [/COLOR]'92 Sahara, 4.0, Auto, A/C, Converted to NIB TF999 Auto 11/08, Relocated Breather, Temp Sender, Transpak, OEM Column Shift, TeraFlex Extreme Short Shaft SYE on '03 TJ 231J, NO T-Case Drop, Tattons 22 1/2", 7" Slip Rear CV Driveshaft, Tattons Front [COLOR="BLACK"]12" Slip[/COLOR] Driveshaft, NO Trackbars, SRS and SOA, OEM rear packs all around, JKS's, 1995 D30, Lockright, JB High Steer, & 3.73 gears, 1995 D35 w/ 30 Spline Ected, Alloy Axles & 3.73 gears, Custom built (by me) Anti Wrap bar using 2 rear tracbars, Welded and Sleeved "Thru Frame" Rear Shock Mounts, Rear Booms, '95 Dual Diaphram Booster and MC upgrade locking 35" Baja Claw Radials, 15x10 Eagle Alloys, 7" Flares, Ramsey Rep 8k, ARB Snorkel, Body Armor Double Hoop Front Bumper, Rocker and Corner Armor, Custom Built (by me) Rear Recovery Bumper/Carrier, Hilift, D-Rings, 30x6 Keeper, CB, Aftermarket Gauges in Gauge Works angled center dash, Trailmax Pro Seats and Center Console, 136 amp 7913 Alternator charging Dual Yellow Tops, 10 KC's = 1300 Watts of Lighting.......... 4480 lbs empty with my softtop, Jim = AKA Ghost183 [COLOR="blue"] Wifes, "once in a whiler"[/COLOR] ALREADY SOLD IT [SIZE="1"]'93 Sahara, 4.0, Auto, A/C, 4" RC kit, (Thanks again Ryan) Standard Shackles, 31x10.5x15 on OEM rims, everything else STOCK.. [/SIZE] [COLOR="Blue"]Tow Vehicle... [/COLOR] '99 Tahoe, soon to be modded[/COLOR] [QUOTE=Mean Max;6554202]BTW I drove the WJ to Dunkin' Donuts today and realized it has [B]GLASS[/B] side windows! What a concept! :D: :cheers2:[/QUOTE] [CENTER][SIZE="2"] [COLOR="Black"]"Important Notice" DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE Regards THE GOVERNMENT[/COLOR][/SIZE][/CENTER] |
#15 |
thats pretty cool, I wish I had known about this when I did my 99+ intake swap. I had to use a tj power steering pump and the pulley that came on it looked like a dog chewed on it so I bought a stock replacement for 25 bucks. Even that one has a small crack in it already, maybe ill replace it with one of these
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
